open element
Car: They all sit.
Engine: LB9,LB9, LS1, LT4, LT4
Transmission: T5, T5, 4L60, T56, T56
open element
i picked up an open element from autozone. edlebrock 1221, its a 14x3" drop base element and wouldnt fit. i had to leave the stock ring on so it would barely clear the coil wires, and the bolt was too short to screw it down. it was 29.99, i'm going to take it back and try to find anotherone somewhere else.
so the drop base ones require you to keep the spacer, but the normal ones dont? I'm going to stay with a 3" filter.
thanks
thanks
Car: They all sit.
Re: open element
this one is a 14x2" raised element, but i want a 3"
http://store.summitracing.com/partde...5&autoview=sku
This is a 14x3" raised with reusable filter
Or the summit brand 14x3 raised filter
what one should i order?
Re: open element
You def don't want a raised based, unless you have a cowl hood.
A flat base will clear the stock hood. I bought mine from Jegs
http://www.jegs.com/webapp/wcs/store...51908_-1_11349
I believe it was part # 555-50022
Car: They all sit.
Re: open element
is there one that summit sells? i live real close to summit and have some summit bucks. when i looked through their listings i didnt find any flat base ones at all.
Car: They all sit.
Re: open element
Thanks, just a side note, in your sig, It's way easier to make a 4th gen look good than it is to make a 3rd gen fast.
I would say it didnt take much for my two 4th gens to look good.
Pac J
05-17-2020 10:44 AM
FueledSoul
09-29-2015 08:58 PM
