idleing at 2,500 rpm
Car: They all sit.
Engine: LB9,LB9, LS1, LT4, LT4
Transmission: T5, T5, 4L60, T56, T56
What could be causing my car to idle at 2,500 rpm? bad sensor somewhere? I'm not getting any codes.
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
Re: idleing at 2,500 rpm
No obvious vacuum leaks or something crazy like crap blocking the throttle open? Is your SES flashing when you start the car to let you know all is good?
Also, I'm not sure at what idle speed the Idle Air Control valve is maxed out at, but 2500 sounds about right for something like that to be happening, like something is causing it to stick wide open. Maybe it needs to be investigated, wiring checked, valve cleaned, tested if possible, and maybe replaced. It could be other things so post back what you find.
the vac lines are attached to the TBI. check for cracks or detached.
spray the base of TBI at manifold and the TB shaft where it exits TB on each side.
I believe you can look into the TBI init to see if the IAC is moving and seated. I think it moves at key on and would be nearly seated at fully warm idle.
1 Post
Car: 1989 Camaro RS (w/Z28 tags)
Engine: 305CID TBI
Transmission: Manual - T-5
Axle/Gears: Stock
When I had my IAC out and started up the vehicle, is was idleing at 2500-3000rpms. So thats a possiblity like stated above.
Car: They all sit.
What part is the IAC? I dont know which part it is. whats it stand for again? i cant remember, intake air something,
thanks
thanks
Car: They all sit.
ive got the book. just like to get my info from others insted.
all my hoses are fine by the way. no leaks there
Car: 1989 Camaro RS
Engine: ZZ4 350
Axle/Gears: BW 9-bolt w/3.73
This may sound like a weird question but does it sound like it's idling at 2500 rpm? Is it possible your tach has gone screwy? When I fried my tach I had an indicated 2400 rpm at a 750 rpm idle. If you pulled you gauge cluster out at any time without unhooking your battery you may have damaged it.
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I was working down by my peddles, and bent the metal sheild around the throttle peddle. It caused my car to idle at 3000+
when my cooling fan switch went out and did not let the engine get above 140 degrees my car would not drop below 2500rpm hope this info helps. what i was told the computer kept trying to warm the car up but couldnt.thats my
Car: They all sit.
i believe my cooling fan had been wired to stay on, or else the previous owner had trouble with it, but it had been rewired somehow. might be something to look into, thanks.
