TBI won't spray gas
TBI won't spray gas
I just bought my first 89 IROC 305 last night from a neighbor. The car's front end is smashed and wires are strun about everywhere, but the car did run. At some point though the fuel pump stopped working. I bypassed the wiring jungle and put a make shift switch on the fuel pump which is now working. Gas is getting to the TBI, but the engine wont run. I don't beleive the TBI is squirting gas at all for the butterflys are dry. If I dump gas in the carb it runs for a few seconds then dies. PLEASE help, I want to get the car in my garage w/o pushing it.
Oh Ya, I check and replaced f/p inj fuses although they didnt look bad. Does the injectors somehow tie into the fuel pump? For instance if the fuel pump dosent get power does the injectors also not get power?
1 Post
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
Replace ur fuel filter....it could be plugged. Also, listen for the fuel pump to turn on when u turn the key in the "on" posistion. Possibily have someone by the tank listening for it.
Eric Natzke
91 Firebird 305 TBI
"It Ain't Stock"
http://members.aol.com/j007golden/91firebird.html
For info on certain parts or mods go to the site below
http://members.aol.com/j007golden/modeval.html
Eric Natzke
91 Firebird 305 TBI
"It Ain't Stock"
put a test light or multi meter on the wires that lead to the injectors. i am not sure wht the reading should be, but there shouldbe something there to tell the injectors to fire when the key is turned. the power should pulse to the injector pretty quickly.
hope this helps
later
tim
91 Camaro RS-LO3,Auto.
14.209@95.46mph
Best 60' 1.917
Check Out The East Coast F-Body Nationals Home Page
www.geocities.com/njspeeder
My MAFB.ORG Home Page
www.mycar.net/mafb/registry/detail.cfm?id=299
DSI Racing Home Page
www.geocities.com/foff667
hope this helps
later
tim
14.209@95.46mph
Best 60' 1.917
Check your distributor module. If the computer isnt receiving pulses from the distributor it wont fire the injectors. We tore our hair out on that one.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Member: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
Thanks to everyone, I think I narrowed it down. I cleaned the TBI connectors and I hear them clicking now when crank is turning over. New Problem though. Gas can flow from tank to TBI, but I don't beleive it's under pressure. I hear the pump working, but I'm not sure if it's really "Working" Is there any good way to tell before I try replacing the fuel pump? Also I only found 1 inline fuel filter, is this normal? Also there is the vapor canister line, which is cut. Does this line need to be blocked off or wide open to the tank?
Well I got it going, turns out the fuel pump was working, but not good enough. I went out and bought a holley blue pump and did a temp. rig with a gas jug. Fires up good!!
92camaroJoe
08-13-2015 06:07 AM
