my 454 tb IAC doesnt match up...any suggestions?
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
the one on my stock tb and on the holley thati just replaces is the "4 in a square" shape. the 454 tb has a "4 in a row" shape. no place has them, and at the dealer it looks like the only one they showed was the "4 in a square" one that i already had. what should i do? any suggestions?
-brian
1991 Camaro RS - ultra blue metallic, t-tops
GMPP 350 HO crate engine - TBI, MSD ignition, SLP exhaust
700R4 - 2,400 stall converter, vette servo
10 bolt - SLP zexel torsen differential, GM 3.42s
z28boy.fbody.com
z28boy@twcny.rr.com
AIM - "Z28 Boy"
1998 Pontiac Grand Prix GT - 2 door, black
-brian
z28boy.fbody.com
z28boy@twcny.rr.com
AIM - "Z28 Boy"
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
match the wires on 350. i have an adapter made by turbo city. 305 you swap the 2 blue wires. here is how mine is. i have a 305.
they are labeled abcd on the plugs
a=blue/black stripe on 4flat
a=blue/white stripe on 4square. (top right looking at back of plug where wires enter female plug)
b=blue/white stripe on 4flat
b=blue/black stripe on4square
the green wires are the same.
c=green/white stripe
d=green/black stripe
o, sorry, just re-read you post.
the 4 in a row is a standard weather pack connector. where do you get em? should be able to find at any parts store.
1 Post
Car: 91 Red Sled
Does anybody know where to find a 3 in row weather plug? It has to be the Male plastic side (with the green gasket on it) and have MALE metal pins. I tried finding them at the local parts stores in Jersey but they suck and then I tried out here in Ohio and still can't find it. So right now the thing is held together with zip ties around TB and nails as "extentions."
, Jon (350 TBI! getting 23mpg highway)
91 Red RS w/grey int, sq stereo (Alpine v12, kicker solo, MB quart premium etc)AIM: JPrevost
- Holley 670 TB unit w/ 1/2" spacer/adapter
- Edelbrock RPM vortec intake
- 350ho 330hp vortec crate motor
- 8" harm. balancer
- Stewart stage 2 water pump w/160 thermo
- SLP tri-y headers to full 3"
- Rebuilt trans w/ SLP shift kit
- Centerline 16x8's all around
- 36/24 mm sway bars
- Full poly bushings, even motor mounts
- SLP LCA and panhard
- Alston SFCs
- Edelbrock 3 point STB
- Global west steering brace aka wonderbar
- Eibach pro kit springs
- Bilstien high perf. struts and shocks
- All this and I still have AC
Car: 1991 Camaro RS
nope..you cant find that connector anywhere. i have looked at all the parts places around. they have a GM IAC connector, but its not the right one. if you can find one let me know.
-brian
z28boy.fbody.com
z28boy@twcny.rr.com
AIM - "Z28 Boy"
-brian
z28boy.fbody.com
z28boy@twcny.rr.com
AIM - "Z28 Boy"
http://force-efi.com/gmwp.htm
if not exactly what you are looking for.
Call Turbo City, they sell a conversion adapter piggyback plug.
1 Post
Car: 91 Red Sled
None of those are what I need. I think I'm just **** out of luck. Need to take apart a WeatherPack Connector and change the pins inside. Stupid mother****ers and their "special" pieces. Why couldn't it just have a standard TPS connector?urrrhhhhh
Z28 boy, what did you use for the TPS sensor to holley unit?
- 8" harm. balancer
- Alston SFCs
Car: 1991 Camaro RS
Jon...you cant find it in a weather pack or whatever? they are everywhere, are you sure you were looking at the right one?
i got the new pigtail for the IAC today. my local GM parts guy is the MAN and he got it for me overnight. but now i dont have time to put it on for a couple days which sucks. oh well, at least i have it.
-brian
z28boy.fbody.com
z28boy@twcny.rr.com
AIM - "Z28 Boy"
-brian
z28boy.fbody.com
z28boy@twcny.rr.com
AIM - "Z28 Boy"
poor guy is gona have a stroke too. like fastbroker in the other post. calm down. z28, maybe get him the pn#. i would but im tired of calling down to the dealership for #'s this week. (ive been for my tb sensor parts costs.)
Car: 1991 Camaro RS
i can get you the part number for the IAC pigtail, but you dont need it with the holley. you need teh tps, which i thought is readilty available at all the parts stores. like every one up here has it, so i dont know why they woundt have it where you are Jon. you just need the 3-inline one, right? that is what TPS i have on my car. if you need me to, i can buy you one up here and mail it to you.
-brian
GMPP 350 HO crate engine - 454 TBI, MSD ignition, SLP exhaust, everything is new
700R4 - 2,400 stall converter, vette servo, shift kit
z28boy.fbody.com
z28boy@twcny.rr.com
AIM - "Z28 Boy"
-brian
z28boy.fbody.com
z28boy@twcny.rr.com
AIM - "Z28 Boy"
I've picked up the inline 3-pin units at NAPA auto parts. I couldnt find the IAC connector anywhere new so I cliped one off a wiring harness in a junk yard.
JP, did you find that 3 pin connector you were looking for? Found out today that its the same plug the GM used on the tps on their tpi cars. Atleast thru 87 fur sure.
Steve
Steve
1 Post
Car: 91 Red Sled
Okay, the problem is the holley units TPS sensor is female housing but the pins inside are female as well. The problem I'm having is finding the male connector with MALE pins. I've looked and I can't find the connector anywhere. The one I had to rig had to be ordered and it was still the wrong part. I'm just going to call up Holley to get the part number if they even know. If anybody has the part number please let me know. Thanks.
- 8" harm. balancer
- Alston SFCs
JP, I don't know if you have anymore access to a tpi harness connector than you do the other but I used one to adapt to my gm 454 tb and it is the same connector you described.
Steve
Steve
i also purchase a new gm 454tbi and the iac has the a female 4 in a row pin settup. i went to the dealer but the parts guy cannot locate the male connector for the tbi. does anybody have the gm part# for this so i can feed it to the dealer?
this looks like a special connector, the 350tbi is totally different. will the wires be coloured the same?
thanks
thanks
<font face="Verdana, Arial" size="2">Originally posted by snflupigus:
d=green/black stripe</font>
1 Post
Car: 91 Red Sled
Somebody get me the TPS sensor and mail it to me, I'll pay you for it. It NEEDS to mate up with the Holley unit. It has to be the male weather pack with 3 prongs and needs to have male metal prongs inside, I can't use it if it has female like ALL the parts stores in NJ and Columbus Ohio. I wish it wasn't this hard to get the stupid part. I called up Holley and they told me what you guys are telling me, that any parts store should have it blah blah. Please e-mail me if you can get a hold of one and see what it'll cost to ship to 43201. I'd like to use paypal if possible. Thanks
, Jon (350 TBI!)
91 Red My website
, Jon (350 TBI!)
91 Red My website
Do you have a NAPA or Pep Boys near you?
1988 T/A,
9" Ford, 3.50 gears, Auburn posi, 700r4 -w- 2100 converter, 360ci, 9.8:1 cr,
AFR 195 Heads, Weiand #7525 intake, Lunati roller 219/227, .479/.480, 112 LSA
Holley 700cfm 4bbl on TBI truck 7747 computer and chip by Howell-EFI
1988 T/A,
old thread, but i thought i would let people know, i can now get all of these plugs. and ill cut turbo city's price in half (tc's price = $20) on the 2 plug conversion ones if you want one of those. if you just need half a plug, they are very cheap. 5 bucks + 2$ shipping.
1Aauto
Sponsored Vendors
09-13-2017 12:58 PM
