2.13" CFI throttle bodies
Car: 1992 Z28 Conv.
Axle/Gears: 10 bolt, 2.73 posi
Hey guys,
Need some opinions. I'm planning to hop up my 84 cfi vette and assembled the following componets...
Offy Crossram intake w/custom top plate
2.13" throttle bodies
Patriot Alum. Heads, 195cc intake runner, 64 cc combustion chamber
Comp Cams camshaft...
"XFI" 268 Hydraulic Flat Tappet Cam shaft
Chevy 262-400ci 1955-98
Lift: .520"/.515" w/1.6 Rockers
Duration: 268°/280°
RPM Range: 2000-6000
LSA 113
This all will be installed on the stock l83 shortblock. I'll also be running a 8746 ecm with prominator and embedded lockers.
Are the 2.13" throttle bodies too big for this displacment?? What are you guys running?
Mark
Duration: 268°/280°
LSA 113
Mark
Terrell351
06-13-2021 01:13 PM
mdtoren
08-16-2015 05:45 PM
