4th Gen Axle in a 3rd Gen Camaro
This topic was posted before but I don't know what the outcome was. I was looking at a 4th gen Camaro axle with disc brake setup to put in my RS and was wondering if this axle has the same dimensions and mounting points as the 3rd generation Camaro. Has anyone done this swap? Also, which 4th gen Camaro axle comes with 3.42 gears from the factory if any? Any helpful input is appreciated.
92' Camaro RS 305 TBI
Best 1/4 mile - 14.6 @ 96 mph w/NO NOS
Best 60' - 1.9 secs
Check it out
https://www.thirdgen.org/rides/index.tgo?action=view&rideid=4860
Best 60' - 1.9 secs
Check it out
Aw crap! I was hoping to use the rearend but only for the disc brake setup. The wheels I'm using with the factory axle are even with the fenders as it is and I think the "go-cart" look you see on lowriders is an insult to a Camaro. Would the 4th rear disc brake setup work with my existing axle?
Best 60' - 1.9 secs
Check it out
Best 60' - 1.9 secs
Check it out
<font face="Verdana, Arial" size="2">Originally posted by snflupigus:
why is this on the tbi board?</font>
Best 60' - 1.9 secs
Check it out
I think that if I went with the 4th gen rearend , my tires would stick out because right now they're even with the fender wells as you can see on the pictures in the readers rides section. Thanks for the information.
Best 60' - 1.9 secs
Check it out
Best 60' - 1.9 secs
Check it out
True they will stick out, but only 1" on each side. Thats not much and it wont look like a Low Rider. It will give your car a differnt stance and one I like. I have seen this done and I think it looks bas *** .
89 Trans Am Turbo 3.8L All stock 43,000 miles #1053 of 1555
Past Thirdgen:
86 Trans Am w/ built 355TPI with SLP goodies and too much other stuff to List. One sweet *** car, wish I would have had a good enough Job to pay insurance on three cars so I could keep it, but for a 89 Turbo Trans Am w/ Low miles, I think I made the right choice!
Past Thirdgen:
1 Post
Car: 91 Red Sled
Moved to suspension board because the rear of the RS is the same as every other thirdgen.
, Jon (350 TBI!)
91 Red My website
, Jon (350 TBI!)
91 Red My website
1992rs/ss
16
01-28-2016 09:58 PM
1992, 1999, 3rd, 4th, axle, camaro, codes, dimensions, engine, firebird, gen, kart, measrements, measurements, offset, powered, snowmobile, vbulletin
