Track Results of Ram Air Box's twin snorkel
Well, my fastest time ever is 15.64 with the weather about 68 degrees, low humidity, no wind, etc. I went to the track on Fri., the weather was exactly opposite. 95 degree temp, 100% humidity, 5-10 mph winds...to say the least not optimal. With the sun still out the car ran consistant 15.80-15.77, but when the sun went down the temp dropped to a freezing 83 degrees and the car began to pick up. I dialed in a 15.72 and I had to get on the brakes hard to stop from running out. I'm not sure what it would have run but I do know that even with conditions that bad, the car would have easily run low 15.6's (I ran my fastest 60 foot ever, a 2.190). My desktop drag 2000 program says that the weather differences would have slowed me about 2.5 tenths so I figure that is about what I got from the Ram Air Box (over an open air filter). All in all, not a bad improvement, I still would like to see the real improvement in ideal conditions.
1991 Chevy Camaro RS TBI w/auto
Mods:
Edelbrock TES Headers, REALLY high flow cat, 2 1/2 in catback flowmaster, 160 stat, hypertech chip, MSD ignition (rotor, cap, superconduct. wires), Bosch quad4 plugs, Ram Air Box twin snorkel, all TBI mods, no smog stuff, no EGR, lots of suspention and alignment upgrades, and a big Chevy bowtie sticker on the back.
Fastest e.t.:
15.64 @ 87.8mph
Mods:
Fastest e.t.:
15.64 @ 87.8mph
Hey thanks for posting the results on this mod. I wonder how much better you would do running the 4" snorkle on the drivers side.
Running the stock 3" OE on the drivers side has to reduce performance. I bet it makes a difference if you are able to open up that side. If you ever find one or two of these, put me down for one and I will do the same. Thanks for the e-mail on the install. I am gonna wait till I can find the drivers side 4" snorkle to do this mod...........bob
91 camaro RS convert,GM crate 350 with LT1 cam,edelbrock 6085 heads,9.5:1 comp, edelbrock TBI intake, 65# injectors, GM cop chip,dual fan conversion,
ultimate TBI mods,TBI spacer,SLP 1 5/8 headers,
3"cat back,Flowmaster,
T-5, centerforce 2 clutch, 3.42 torsen posi,alston SFC's,Global West LCA relocation brackets, edelbrock STB
My305, whats you 1/8mi. time on that run you ran at 2.190 60ft. I ran a 2.215 60ft with a 9.963 1/8im time today. One other thing you might want to consider is changing your plugs back to a single electrode plug to unshroud the spark. You might find another tenth or two.
My 1/8 mile time is a 9.998 at 70.13 mph. I was told that a 4 electrode plug promotes a complete burn, and smoother acceleration, but I could be wrong. They cost enough (6 something a plug X8) so I was hoping they were good. Anyone else think I cold pick up some time going to a single electrode? I just bought the best (most expensive)plug they had, I'm sure there could be better.
Bob...I'm sure if I switched to a 4in driver's side snorkel it would improve the ram effect. I know a guy that works for Chevy dealer and I'm going to see if he can find a 4in snorkel, if he can I'll try to get you one.
Mods:
Fastest e.t.:
15.64 @ 87.8mph
Mods:
Fastest e.t.:
15.64 @ 87.8mph
My305, with your ignition setup try going back to a stock AC plug and gap then at .045in. If you don't mind changing plugs, there cheap and if they don't show any improvment at least you'll have a extra set of plugs for an emergency. I'd say you will not see any drop off from the plus-4's your running now.
where did you duct the ram air tubing to, under the car? or behind the head lights like stock?
congrats on the new times. keep working on those 60's, they are where the et is at.
lata
tim
91 Camaro RS-LO3,Auto.
14.209@95.46mph
Best 60' 1.917
Check Out The East Coast F-Body Nationals Home Page
www.geocities.com/njspeeder
My MAFB.ORG Home Page
www.mycar.net/mafb/registry/detail.cfm?id=299
DSI Racing Home Page
www.geocities.com/foff667
lata
tim
14.209@95.46mph
Best 60' 1.917
I saw another post ont this board with pictures of The TPI air scoop/snorkle ducted to a TBI aircleaner. Does anyone know the flow numbers of the TPI scoop/duct work?
It seems that this set up with a single
hose going into a modified TBI aircleaner would be very clean and relatively easy.
The pictures I have seen show the TPI set up used along with the drivers side snorkle,
which I am sure brings in a lot of air but looks a little funky. Just wondering about the flow of the TPI set up...........bob
The ducting goes to the stock location on the radiator support. It mounts in the pre-existing holes (89 and up)
rsilver...do you have an address for that post?
Mods:
Fastest e.t.:
15.64 @ 87.8mph
Mods:
Fastest e.t.:
15.64 @ 87.8mph
my305, check out the dual snorkle air cleaner post above. They have a couple of links with pictures. Let me know how you thinkw it will work with the ramair box..........bob
1992rs/ss
05-19-2020 07:02 PM
9192camaro
16
02-03-2019 12:21 AM
Brinkkl2000
08-04-2018 08:29 AM
1992rs/ss
16
01-28-2016 09:58 PM
