.544 lift cam
.544 lift cam
i got my cam back from the shop after getting it dialed in to find the lift do u guys think that a .544 lift cam is too much or is perfect for my 355,will i have a problem passing inspection its gonna be a daily driver
1 Post
Car: 91 RS Convertible
Engine: 355
Axle/Gears: 2.73 peg leg
Do larger lift cams pull more vacuum, or is it the duration that pulls vacuum? The reason I ask is, I had some friends who put a cam with about that lift in a car and had to run a vacuum canister to keep their brakes.
91RS convertible 355 TBI 65# inj. custom compcam grind .480/.480, Edelbrock TBI manifold, open element, hedman hedders, Y-pipe, cheap cherry bomb muffler, Hypertech cop car thermomaster, Accel coil, wires. 2.02/1.6 cast iron heads. Engine specially made by Pflugerville machine shop. Forged bottom end, balanced. Coming soon: Vacuum controlled FPR, better exhaust, Torque converter, DIY PROM, bigger TB.
1 Post
Engine: 355
Realizing this probably belongs in the general engine section, what exactly is overlap?
Guest
Posts: n/a
Put simply, overlap is the amount of degrees both valves (intake and exhaust) are open at the same time.
at www.compcams.com they have a great article about all that cam stuff you want to know.
[This message has been edited by madmax (edited August 15, 2001).]
