egr problems
1 Post
Car: 1991 camaro RS
Engine: CharlesOdoryOB
Transmission: 82513892892
Axle/Gears: pbr disc 3.27 nine bolt
egr problems
ok ive put on a new egr new egr solenoid and cleaned out the egr ports in the intake
the vacume lines are not plugged and the solenoid is working
i still have code 32 on the freeway or anytime above 50 mph
the ses light stays on till i shut off the car and dosnt return till ive been above 50 for 5-10 min or so all of the symtoms lead me to believe its still egr related so what can it be
thanks in advance
thanks in advance
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Re: egr problems
Code 32
This is one of those pesky codes to troubleshoot:
The ECM operates an EGR control solenoid to control EGR valve. EGR valve is normally closed, but ECM can pull (circuit 435 - Gray wire) down to ground to activate exhaust gas recirculation. ECM checks EGR effectiveness by periodically turning on and off EGR valve while monitoring for vacuum variation by MAP sensor at cruise speeds (above 50 mph, 35 to 55 Kpa, TPS 9% to 20%, no throttle change during test.). With EGR valve in closed position manifold vacuum will be greater with EGR being open. The change (delta vacuum) as measured by MAP sensor must be within acceptable values or otherwise code 32 will be set.
Vacuum drop due to EGR activation will also depend on exhaust system. If you have a free flowing exhaust system there will be very little back pressure and as result very little vacuum change between on-off. Replacement EGR valves come with restriction plates – you may have to play with them to find the right one.
Also there is the usual manual EGR valve check routine with a manual vacuum pump, to see how much manifold vacuum changes at about 2000 RPM.
I hope this helps.
RF
I hope this helps.
RF
Ghettobird52
07-05-2024 11:18 PM
