Boring TBI to 48mm
Car: 88 IROC
Transmission: auto
Boring TBI to 48mm
Does anybody know what kind of shops i should look for so i can get my stock TB bored out to 48mm?? Turbo City has really ridiculous prices.
Also, anybody have the stock 48mm TB plates from a TPI car? Or know of a place where i can get them? Thanks
Pat Hirsz
www.iit.edu/~hirspat/MyPage2.htm
88 305TBI
Mods:Hooker Aerochamber 3" exhaust, no cat,SLP 1 5/8" headers and y-pipe March pullies, no smog, 180 thermo,
14x4 K&N, 3.42 gears(open), Ultimate TBI Mods,AFPR,MSD(ignition,coil&wires),Edelbrock TBI Manifold, 190ltr/hr fuel pump,
Eibach springs with KYB's all around,
Harwood cowl hood, Z-28 wing, fresh paint(black)
120,000 miles, 5spd, T-tops
0-60mph-7.2s-Gteched
92 RS, 305TBI, auto, 3.08 gears, 180 thermo, glasspack (no muffler)
Pat Hirsz
88 305TBI
Any good machine shop should be able to bore it out for you, but most shops charge $50 to $75 an hour, I'm a machinist and I just spent about 3hr. boring mine out, milling off the ridge above the bores, polishing it and making new throttle plates, I'm getting it ready for a 350 I'm building. If you could find the throttle plates yourself that would save them from having to make some to fit it.
92 Camaro RS 5.0 5-Speed
L98 Alu. Heads
SLP coated headers
Dynomax cat-back
14" open air cleaner
1998 Dodge Ram SS/T
L98 Alu. Heads
SLP coated headers
Dynomax cat-back
1998 Dodge Ram SS/T
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
plates probably took the most time huh?
want to make me some 58mm ones? how much would you charge?
o, and yes, i said fifty eight.
if youve got the thing taken apart, i cant imagine it taking any longer than one hour to bore it out. the ridges etc, polishing, another hour. those plates probably took the third hour huh?
Car: 88 IROC
Transmission: auto
I've already removed all the ridges and radiused the bores in, i just need to find the plates now and get it bored out. I have a friend who has a welder and knows how to weld, maybe we'll try adding some extra material to the TB and see if i can get it bored out to 2". But how do i go about polishing it and is it necessary?
Glowsock
09-11-2015 11:09 PM
