Cylinder Wall Polishing from excess gas?
Hello. How can you wash the cylinder walls with gas on a EFI system? Wont the computer or you can get it programmed to inject the proper amount of fuel according to engine demand. my engine right now is 350 ci and planned on going to Edelbrock MPFI with 383 and later supercharged. I wanted to get bigger injectors before i buy so i dont get stuck with the old ones. The 29 lbs/hr injectors that i was going to get support up to 464 hp. so will my cylinder walls polish if i use this system on my 350?
Hotrodboba400
12-10-2019 07:07 PM
