i just got a 454 tb form ebay w/afpr mod...some questions...
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
i just got a 454 throttle body from ebay. the guys says that it is from an '89 truck. he also said that he did the afpr mod. should i be worried that he somehow messed up the afpr mod? just wondering what i may have gotten myself into.
any tips on recinditioning the throttle body at all? anything i should look out for?
thanks guys..i apprectiate it.
-brian
1991 Camaro RS - ultra blue metallic, t-tops
GMPP 350 HO crate engine - TBI, MSD ignition, SLP exhaust
700R4 - 2,400 stall converter, vette servo
10 bolt - coming soon - SLP zexel torsen differential, GM 3.73s
z28boy.fbody.com
z28boy@twcny.rr.com
AIM - "Z28 Boy"
-brian
z28boy.fbody.com
z28boy@twcny.rr.com
AIM - "Z28 Boy"
Car: 1991 Camaro RS
so i am going to use my injectors, and that will be enough fuel? what is the stock injector's flow rate?
i am assuming that the increased fuel pressure that i will be running will compensate for the smaller (stock) injectors, am i right?
Jon...the reason that i am trying out a 454 throttle body is because everyone says that the holley unit is garbage, so i thought i would try it out. and i still can't get my TPS set right on my holley, so hopefully the 454 will be better in that respect. i think that the TPS issue has caused a lot of my problems.
thanks guys.
-brian
z28boy.fbody.com
z28boy@twcny.rr.com
AIM - "Z28 Boy"
thanks guys.
-brian
z28boy.fbody.com
z28boy@twcny.rr.com
AIM - "Z28 Boy"
