9 inch vs 14 inc air cleaner...
right now i have a k&n open air cleaner on the car(9 in.) i was considering getting the big 14 inch one with the filter top, and i'm trying to justify spending the $140 bucks it costs.
does anybody have any experience with the 14 inch versus the 9 inch. is there much performance gain? also what about the new open element top piece, anybody got that, any good?
space isn't an issue, since i have the cowl hood. thanks.
1990 Camaro RS
305 TBI Auto
K&N Open Air Element, Edelbrock Performer Intake, Edelbrock Headers,Catco Hi Flow Cat, Edelbrock Exhaust, Hypertech Underdrive Pulley's, Jacobs Ignition, Fast Chip PROM, B&M Shift Kit, B&M Mega Shifter, 3.73 Rear with Auburn Limited Slip, KYB GR2 Gas Shocks and Struts, Eibach Pro Kit Lowering Springs, Edelbrock 3 Point Strut Tower Brace, Baer 13 in. Slotted Rotors with Metallic Pads, American Racing Torq Thrust II 16x8 Wheels with Toyo 245 50 VR 16 Tires, 3 in. Cowl Hood, A little weight here and a little weight there.
1990 Camaro RS
305 TBI Auto
$140???? where are you so I can hold a garage sale?
I got my 14x2.25" PAW open element for $17(paper element). A couple weeks later I got a 14x3" k&N for like $35
-Tas
'89 Formula WS-6
[soon to be Torch Red with black hood and headlights =) ]
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
Super GRK_Taz World
EFI & Intake Options
AOL IM: superGRtaz | ICQ 82881207
-Tas
'89 Formula WS-6
Super GRK_Taz World
Car: 91 Red Sled
Summit has there cloth element and 14" drop base air cleaner for only $15 if you don't mind looking at Summit every time you open your hood. I couldn't care less. $140 is way too exensive for any air cleaner, heck, that sounds like a new dual snorkel air cleaner with all parts.
, Jon (91 RS too many mods to list)
Dale Earnhart, you have done so much, you will be missed.
ahh I missed the part that said open filter top. thats why it would be so much. 14x3 is a lot of area, you wouldn't need that top.
The PAW brand is very clean looking, chrome, no letters, slightly coned upward. I needed a new "carb stud" for it to fit. the original was too short. I had to run the chrome lid up side down when I bought the 14x3 filter so I could get to work so I could put in the new stud.
There's a few cheaper ones.
Edlebrock and www.sbfilters.com both make cloth filters
1989 Camaro RS LO3 WCT5 0-60' 2.34 1/4 15.8@87mph
http://350.StreetRacing.org
The posi unit breaker.
the pricing stuff was just off the top of my head. i'm not worried about that, so much as is there any real performance gain with the 14 inch air cleaner. or should i just maybe buy an open top for my 9 in. there like $30.
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
i think that the 14" is overkill for our cars. i have seen a million cars that make tons of horsepower with only a little 9" one. and i see it a LOT...they always have smaller air filters than the 14"x3" on my car.
the k&n filter lid or whatever the hell it is is also overkill. i bet that the 14x3 with that top will floe like 2 thousand cfm or somthing insane like that. its just wayyy too much air than most of us need. if you like the way it looks, then go for it, but as far as performance gains, i dont think you need it.
just my 2 cents.
-brian
1991 Camaro RS - Ultra Blue Metallic, T-Tops
GM 350 HO Crate Engine - Vortec Heads, Edelbrock Intake, Holley 670 CFM TB, Edelbrock Water Pump, March Pulleys, MSD 6AL, Blaster Coil, 8.5mm Super Conductors, Cap and Rotor, Rapidfires, Hypertech Fan Switch & Chip, SLP 1 3/4" Stainless Headers, 3" Cat Back, Flowmaster 40 Series
700R4 - 2,400 Stall Converter, Vette Servo, Shift Kit, B&M Super Cooler
GM 10 Bolt -coming soon Auburn Pro Series Differential, Richmond 3.73s
Brian's 1991 RS Central NY F-Body Association
Join the Third Generation F-Body TBI Web Ring
z28boy@twcny.rr.com IM name: Z28 Boy
just my 2 cents.
-brian
morrow
01-13-2024 12:29 PM
IROCZDAVE (88-L98)
09-02-2015 08:43 AM
