Rerouting heater hoses/bypass valve.
has anyone rerouted the heater hoses and bypass valve so they don't just sit above the valve cover banging away on things??
How did you do it.
That routing is pissing me off big time and i am going to change mine.
Any ideas??
Mike
1988 Camaro Sport Coupe305TBI-4spdAOD-2.73open in "bought stock" condition. That'll change if it stays around here much longer
How did you do it.
Any ideas??
Mike
Car: '89 Camaro Convertible
Engine: LB9 Heads/LT1 Cam Holley 670 Carb
Transmission: T5 Manual
I know how you feel. I was thinking about replacing the two hoses with something maybee more flexible ur using some type of 90* elbow fitting coming out of the firewall. to route everyting down alnog the firewall. I havn't given it alot of thought. I know Paplo just stripped his out lost use of the heater though. Mine is a summer driver only so I've considered that but I dont want to lose the defrost on cold mornings. Any other ideas?
Black 1989 RS Convertible w/43,000 mi.
Excellent Condition
LO3 305 w/TBI
12 PSI Fuel Pressure
6* Timing Advance
MSD Coil And Wires
Open Element 14x3 K&N
Hypertech Thermomaster
160 Degree Thermostat
Low Temp Fan Switch
Eddlebrock RPM Muffler
No Cat/No AIR Injection
B&M Stage 2 Shift Kit
17"x8.5" ATP 5 Spoke Alloys
P 245/45 Goodyear Eagle
HP Ultra Plus Tires
Lakewood Control Arms
Lakewood Pan Hard Rod
Coming Soon:
Hedman Headers & Y Pipe
12 Bolt With 3.73 Gears
NOS System
Excellent Condition
LO3 305 w/TBI
6* Timing Advance
MSD Coil And Wires
Low Temp Fan Switch
HP Ultra Plus Tires
Coming Soon:
NOS System
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
i took out my A/C so i had a lot of extra space. since then i have taken out my heater system, so now i dont have anything..here is what i did though...
whatever the hell that silver/aluminum anister thing is that is part of the A/C system (yeah i know...i shoudl probly know this but i dont). well what i did was use the bracket that held that to the heater box and used it to hold the bypass valve. i had to mess around with the hoses if i remember correctly, but i dont think i had to buy anything new..i just cut the existing ones. i will try to see if i have any pics, if i find them i will post them.
-brian
1991 Camaro RS - Ultra Blue Metallic, T-Tops
GM 350 HO Crate Engine - Vortec Heads, Edelbrock Intake, Holley 670 CFM TB, Edelbrock Water Pump, March Pulleys, MSD 6AL, Blaster Coil, 8.5mm Super Conductors, Cap and Rotor, Rapidfires, Hypertech Fan Switch & Chip, SLP 1 3/4" Stainless Headers, 3" Cat Back, Flowmaster 40 Series
700R4 - 2,400 Stall Converter, Vette Servo, Shift Kit, B&M Super Cooler
GM 10 Bolt -coming soon Auburn Pro Series Differential, Richmond 3.73s
Brian's 1991 RS Central NY F-Body Association
Join the Third Generation F-Body TBI Web Ring
z28boy@twcny.rr.com IM name: Z28 Boy
-brian
Car: 1991 Camaro RS
here is an old pic that kind of shows what i did. i thik i took one of the hoses and put in in backwards and it fit a lot better where i had it. its kind of hard to explain.
-brian
[This message has been edited by Z28 Boy (edited February 15, 2001).]
