Need help installing a manual switch for my fan!!!
I just installed a new radiator fan and I would like to install some wiring and a toggle switch that would enable me to turn on and off my fan manually and automatically. thanks,
big tex
big tex
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
1 Post
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
There is a guy names "Duke" on here that has the scymatic(sp?) on how to do the manual fan switch. Ask him. I beilve he is some posts near the top somewhere.
Eric Natzke
91 Firebird 305 TBI
"It Ain't Stock"
http://members.aol.com/j007golden/91firebird.html
For info on certain parts or mods go to the site below
http://members.aol.com/j007golden/modeval.html
Eric Natzke
91 Firebird 305 TBI
"It Ain't Stock"
The easiest way to wire it up IMHO is to run a wire from a switch in your dash to the fan switch in the passenger cylinder head.
Connect the free side of the dash switch to ground.
I like this method for a couple of reasons. It doesn't change the stock operation of the fan. It's safe electrically. The fan shuts off when you turn the key off.
I personally prefer a fully automatic system. I would put a lower temp fan switch in to keep coolant temps down.
[This message has been edited by Brent (edited January 24, 2001).]
Car: 92 RS
Engine: 406 SBC
Transmission: 4R70W
Axle/Gears: Moser/Strange 9" 3.73, spool
big tex, I got the E-mail, the schematic shows how to retain the stock system and still use a manual switch. Anyone else need a copy?
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
Duke, i odnt know how your schematic showed it, but the wire fo rthe fan switch is right in the big wiring harness on the firewall near the power brake thing. if i remember correctly, it was a green wire??? i just tapped into the wire and ran a switch into the interior of the car.
-brian
1991 Camaro RS - Ultra Blue Metallic, T-Tops
GM 350 HO Crate Engine - Vortec Heads, Edelbrock Performer Vortec Intake, Holley 670 CFM Throttle Body, Open Air Cleaner w/14"x3" K&N, SLP 1 3/4" Stainless Headers, Edelbrock Victor Series Water Pump, March Unerdrive Pulleys, MSD 6AL, Blaster Coil, 8.5mm Super Conductors, Cap and Rotor, Hypertech Fan Switch & Thermomaster Chip, AC Delco Rapidfires, 3" Cat Back, Flowmaster 40 Series Muffler
700R4 - 2,400 Stall Converter, Vette Servo, Shift Kit, B&M Super Cooler
GM 10 Bolt -coming soon Auburn Pro Series Differential, Richmond 3.73s
Brian's 1991 RS Central NY F-Body Association
Join the Third Generation F-Body TBI Web Ring
z28boy@twcny.rr.com IM name: Z28 Boy
-brian
Car: 92 RS
Engine: 406 SBC
Transmission: 4R70W
Z28 Boy, I love your car. Guess because it looks like my car.
That's how I originally planned on doing it, but the guy that had the car before me removed the relay and had the fan running whenever the key was on, so I had to do it this way. There's alot of ways to do this, this is just one of them.
Car: 1991 Camaro RS
Duke...
Thanks a lot man...do you have any pics of your car? I would like to take a look at it.
-Brian
-Brian
1 Post
Engine: 3.8
Axle/Gears: Dana 60
http://www.theduke.cz28.com
Theres the b*tch's site.![](https://www.thirdgen.org/messgboard/biggrin.gif)
Eric Natzke
91 Firebird 305 TBI
"It Ain't Stock"
Eric Natzke
91 Firebird 305 TBI
"It Ain't Stock"
TA8487
08-16-2015 12:21 PM
