ALDL diagnosig with macintoch OSX
1 Post
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Hey, im doing some research on doing diagnoses with a iboockG4.
I have a ALDL cable w/OBD1, USB version. But cant get any of the diagnoses sofwears to open. What application do I ned to use?
Id really apreciate some instructions.
1 Post
Car: 91 Trans am
Id like to try the winaldi. Is there another way to go then buying the Microsoft
virtual PC for Mac?
virtual PC for Mac?
Car: 1988 Monte Carlo SS
Engine: 5.7L TPI
I don't think buying Virtual PC for Mac is going work. It might. But the problem with WinALDL is that it is a program that is time sensitive to how fast it runs.
Honestly, buy an older beater windows laptop. For the cost of Virtual PC, you should be able to find something. I have an old Pentium 75MHz 24Mb ram laptop that I use... (Windows 95)
Your 2nd option is a new MacBook. Needing to run WinALDL is a great excuse to convince the CFO that you need a new MacBook... (I have a new MacBook - it can run WinXP)
1 Post
Car: 91 Trans am
Does your MacBook run Mac OS X v10.4 Tiger? If it does shouldent my ibook g4 work for vinaldl?
Engine: 5.7L TPI
You are overlooking the fact that Mac OS X 10.4 runs on Intel CPUs and PowerPC CPUs. Your iBook has a PowerPC CPU in it, where as my MacBook has an Intel CPU. These CPUs are completely incompatible with each other, but Apple has written Mac OS X such that it will run on either CPU. I think all of Apple's software now ships as a 'Universal Binary', meaning that the program files contain the code for both processors. It's really quite slick how they did that.
A MacBook can run WinXP natively at full speed, where as for you to do the same thing, requires a Intel CPU emulator such as Virtual PC.
