385ci 4brl TBI 11SEC CAMARO RECIPE!!!!!!
350 block, 40 over, COMP 280 ROLLER CAM Duration at 50 is 224 lift is .533 with 1.6 rocker. Fuel injection unit is from Howell Engine Development 900CFM 4brl Holly, Holly 4brl EGR Projection Intake manifold, Ported world Sportsman heads, eagle 3.750 stroke crank, Keith black pistons, fluid dampner. Compression ratio aprox 10.2, single snokel Ram air kit. This car idles fairly smoothly and will pass emmisions. The fuel injection hooks up to the factory injector harness and uses a custom burned chip. This engine produces aprox 460 HP and looks factory stock. This fuel injection system also worked great on my previuos 315HP RHS 350. My car before ran 8.60 1/8 with the 315Hp engine my freinds 99 Trans Am ran 9.55. My new combination should run mid 7.70 in 1/8th which is 11.90s teritory! Anyone looking to build a similar car can email me at jason_w926@yahoo.com.
99 Trans Ams run a lot faster than 9.5 dude..
unless your friend can't drive.
I ran a 8.75 on a 13.6 pass a long time ago..
Still a lot of good info..
Shane Buss 92 Firebird 355, Holley 750 Carb, Vortec 1.94/1.50 Heads (Ported,Polished,Milled .025), 10:1 Comp Ratio, Cam Specs 224/234 498/520, 1.6 Roller Rockers, Hooker Headers, Flowmaster, !Cat, 3.73 Posi, Msd 6A Ignition Cyb. Speedo box
http://users.ev1.net/~sdbuss/index.html
Note all girls on web page are x's, and will be removed when i get more time
OH i forgot. WEIAND SUPERCHARGER
junkcltr
08-02-2019 11:12 PM
92camaroJoe
08-13-2015 06:07 AM
