Injector pod spacer
Car: 92 & 93 caprice 9c1's
Engine: L05's
Transmission: 4L60's
Axle/Gears: 3.42's one G80, one open
Injector pod spacer
Okay, Im going to rebuild my TBI, I plan on doing the adjustable fuel pressure mod and adding an injector pod spacer.
Which spacer should I get? Jegs has one for 19.99. ANyone know of any cheaper ones?
Also should I have my injectors cleaned? How much does it cost? Who does a good job and is inexpensive?
Car: 1991 Trans Am Convertible
Axle/Gears: 3:08
dude don't buy a spacer.for the pod...when you buy the kit to refurb the tbi you will get another gasket with it...those gaskets are thick enough you can double stack them and get the same space as most spacers....Also the gaskets are not sealing up anything so it wont hurt to do this..(mines been like this for bout a year)...and the screws are long enough to reuse too..
