My ultimate TBI idea
305 vortec heads, this edelbrock victor Jr 2 barrel intake, good cam, 454 TBI, LT4 or other good cam.
The 305 vortec truck was rated at 230HP so this should be way over that. what you think? I already did the 14x3 K&N flat based open element with open Formula hood.
Tas
AOL IM: superGRtaz
ICQ: 82881207
[This message has been edited by Tas (edited September 24, 2000).]
Tas
AOL IM: superGRtaz
ICQ: 82881207
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
can you use a 2-barrel intake with TBI? i didn't think you could.
-brian
1991 Camaro RS
Ultra Blue Metallic, T-Tops
GM 350 HO Crate Engine - Vortec Heads, Edelbrock Performer Vortec Intake, Holley 670 CFM Throttle Body, Open Air Cleaner w/14"x3" K&N, Edelbrock TES Headers, Edelbrock Victor Series Water Pump, Accell Superstock Wires, Cap, and Rotor, MSD Blaster Coil, Hypertech Fan Switch & Thermomaster Chip, AC Delco Rapidfires, 3" Cat Back, Flowmaster 40 Series Muffler
700R4 - 2,400 Stall Converter, Vette Servo, Shift Kit, B&M Transcooler
Brian's 1991 RS
Central NY F-Body Association
-brian
1991 Camaro RS
Brian's 1991 RS
I'm not 100% sure yet. I went to PAW and really liked the idea of it. Its a great looking intake. The vortec ports are nice and tall. They remined me of 340 Mopar ports. Next time I'm gonna see how well TBI gaskets fit ont he top.
Tas
Tas
Looks like that manifold would work!!! You should measure the 2bbl opening to make sure that the 2" bore TBI will be about the same size. You may have to 'hog' out the manifold to be 2"??? Looks pretty big in the picture, though. May be 2" exactly, now!!! You will (probably) have to make your own TBI adapter plate to center the TBI blades over that 2bbl hole but that setup should work REALLY well... IMO, anyway.
In fact, I may do the same thing with the 2V Victor Edelbrock for older-type heads because it's such a good idea. The only thing I don't like about it is that if you wanna go back to 4bbl carb, can't do it. But I like it, man!!!
[This message has been edited by FastBroker (edited September 25, 2000).]
yes that pic if for vortec heads. I just went back to PAW. it looks like the 2 barrel intake is not wide enough for the TBI. BUT there is sufficient material to have the bore widened near the top with a gradual taper.
1 Post
Car: 89 Formula
Transmission: TH 700R4
looks like you have some good ideas but why
go with the 305 heads? When you can go 350 heads with larger valves, better flowing more power.....
88 IROC the best RS ever made!
well except for the BC4s
Car: Turbo Buick
Engine: 3.8 V6
btw i can tell simply by the bolt pattern of the carb flange, that manifold is nowhere near as wide as it needs to be
and why do you wnat to use a two barrel manifold? any particular reason?
Car: Turbo Buick
Engine: 3.8 V6
well, i dont think so but maybe theres something im missing
heres the way i see it
the whole point of that manifold is to keep the velocity DOWN
because, on a motor which would use a manifold like that, the velocity through a two barrel carb is INCREDIBLE, for instance, Nascars pull something like 16 inches of vacuum at WOT and im pretty sure they use a four barrel carb and an intake like that
reason why its so tall is 1st to increase plenum volume, and second, to keep the fuel from SLAMMING into the floor of the plenum which is likely to happen with a two barrel carb having fuel drawn out at ludicrous speeds and air moving through it in the same manner (air makes turns better than fuel)
IMHO, its not a bad idea but its basically the same thing a well designed adapter would do on a regular 4 barrel intake. Not that this fuel puddling thing is a huge problem with tbi.. its obviously no where near as bad as carb
db057
08-11-2015 10:11 PM
