Air Intake from a V6 RS
Car: 91Camaro RS
Engine: 305TBI
Transmission: 5-Speed
Axle/Gears: 3.08
Hi, I saw a dual snorkel (looked the same as a TPI) in a V6 RS..... Are they the same size as the V8's intake? Will that give me much better flow than the stock TBI setup now? I'm still debating tryin to make my own cold air intake/dual snorkel, or just getting an open element.
Car: check
Engine: check
Transmission: check
Yes, same size as the V8 TPI intake/air-cleaner assembly. The one difference is that the V6 unit has a mount for an IAT sensor. Someone here has used one of these on his TBI setup. A search may find it. He posted pictures of it too. Looked good, nice clean setup.
IIRC, he plumbed it directly inot the front of a stock air cleaner housing.
RBob.
RBob.
1 Post
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
Here is a link to one similar to what you are talking about. Eventually, I'm going to do the same.
1992 Trans Am
05-10-2023 07:19 PM
