What size injectors are these?
I can't find info on these injectors anywhere, the first one is no. 34085 (red prongs) and the other is no. 5233565 (black prongs). Thanks.
http://www.turbocity.com/default.php?cPath=16_30
Check this out. This may help you with finding the size of the injectors. Good luck.
Are those GM part numbers you listed?
Finally the server's up again! The red one came off a caddy so I'm not sure, but I know the other's off a chevy. The link you left didn't work, where do I look it up on turbocity's home site? Thanks again.
Didn't see my injectors there, but thanks. If it helps the other numbers on the injectors are 0230 (black) and 2 15 4 (red). The pintle on the black injector is smaller and doesn't have a needle on the tip. Any ideas?
http://home.earthlink.net/~jcgebhart/msindex.html
This link has injectors and part#'s. All injectors have a two-color code on top unless someone rubbed it off. These part #'s are for TBI, but I think beause you have a 2.8L - you're looking for MPFI injectors for that engine, no?
Aready tried that link too, but thanks. I guess the color code must've rubbed off because there's no markings on them, and yes they're tbi injectors. I have a 2.8 in my car because the block cracked on my 350 when I left it outside with plain water in it ( still kicking myself for that), as soon as I find a decent core I'm going to transfer all the tbi equipment over to it.
92projectcamaro
01-18-2016 08:00 AM
toronto formula
11-10-2015 06:17 AM
