is there a way to get 300hp from a tbi
Car: 1992 Trans/am convertible
Axle/Gears: 2.73 drum WS6
Yup.
I know a guy pulling 315hp crank with a 305tbi.
But, most people here will tell you that its not possible.
So, dont get too discouraged.
Tunning, port and and valve job, full exhaust, 3:23 or 3.42 gears will get you decent performance. Dont need to bore it necesseraly.
(If you wanna get cocky, 125 shot will do the trick)
Car: 1983 G20 Chevy
Transmission: 4L60
Originally posted by iroc22
You'll need to dump the 187 casting heads for any reasonable power level.
1 Post
Car: 93 GM300 platforms
Engine: LO3, LO5
Transmission: MD8 x2
Lo-tec ran 13.6 with a 193 casting Caddy LO5 engine that also had the cam swap + exhaust.
Reasonable power can be made with stock castings. More power can be made with ported heads.
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
The heads would be pretty far down on my list of mods too. Way after exhaust, cam, intake, and getting a 350.
Whats up with the influx of tuned port guys lately?
Originally posted by kdrolt
Dewey316 made 208 rwhp with stock 187 castings, cam swap, and exhaust on a 305, and ran 14.5.
Using a 350 is obviously going to get you closer to a 300hp goal. Anything beyond that will need new heads.
I dicked around with 187's before when I had a TBI car, I didnt get very far with those heads, ended up swapping for S/R 305 Torquers.
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
I know it is. But I was just shy of 240rwhp with the 416 heads, and the same cam. at 12% loss that is about 270 hp. Its getting closer to the 300hp mark, and I really don't have much money tied up in this, it is a pretty easy buildup.
I was making 275 RWHP before bumping FP and EBL. Thats a stock short block 350 Xfire.
Car: Camaro Convertible RS
Engine: 355 TBI
What kind of heads should I slap on my built 355 short block? I'm really don't have any idea what combo would work best with it.
Car: A Camaro
Engine: Weak
Transmission: Weaker
big flow heads may not be best for street driven application. especially TBI. cheap heads may cause other issues. i happen to have a professional engine builder as an aquaintance/business relationship. the latest heads coming from Edelbrock(cnc) are perfection. in his humble opinion having set up more than a couple engines. he is a total frame off restoration specialist. now again not the highest flow(rpm) but good velocity which means easier to tune.
chev vortec is another lower cost alternative.
