rocker arms?
Car: 92 c1500
Engine: 355ci
Transmission: 700R-4
rocker arms?
im rebuilding my tbi engine and i was wondering do i have to use self-aligning rocker arms? from what i understand u have to use them on the stock heads, but im not using those i have Worlds s/r torqurer heads?
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
You can just re-use your stock self-aligning rocker arms. Not sure how the World heads are setup, but your choices are to run self-aligning (S/A) rocker arms or to run Non-S/A rocker arms with guide plates and hardened pushrods. Either way is fine, S/A is easier if you already have the r-arms.
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
Originally posted by bluechevy194
ok thanks for the reply, ill just order a good set of self/aligning roller rockers
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Depends on how things are set up. If you have the narrow slot pushrod guides in the heads or guide plates, you run non-SA rockers. Some TBI heads have the narrow slots with the SA rockers. Potentially you could just run non-SA rockers if the cost was less for aftermarket stuff.
EDIT: I do remember seeing someone here run non-SA rockers with the 87+ narrow slot heads and have the pushrod wear into the head. Not sure on what the circumstances where...
92rsvortec350
19
10-09-2015 10:39 AM
