T/B adapter plate?
T/B adapter plate?
New to this site but been with the LS1 TECH site for a while now with my built 2000 SS CAMARO, now I'm rebuilding my 1992 RS Camaro. I've built a 355 with mild cam to replace the 305, now for the T/B up grade's I'd like to go with the Edelbrock performer intake and a up graded T/B but I can't seem to find the manifold T/B plate on Turbocity's site https://www.thirdgen.org/techbb2/sho...hreadid=262641
I've used the search but can't seem to find it so any help or suggestions on my build would be great,
Thanks!
Thanks!
1 Post
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
as a suggestion i might throw out that you should think of a different intake than a plain old performer. Thats just my opinion though. There performence is sorta lacking compared to most of the aftermarket manifolds.
Then again if you got a different 1 you'd need a carb to tb adapter so thats up to you.
Car: 1991 Camaro RS
Engine: stock 305
Axle/Gears: 4th gen with 342's
I have tried several different intakes myself and the single plane intakes run very well with stock or mild mods...Good throttle response ...just my thought
Thanks for the input's and from what I was reading when I did a search I was under the impression the dual plain intake was the way to go for a injected T/B setup so the single plain Performer RPM would be a good choice with a high flow T/B.
Thank's!
Thank's!
1 Post
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
much better choice in my opinion.
Btw i didn't mean go dual plane i could realy care less if it's single or dual (i like dual myself but,) the flow quality of that particular 1 has trouble keeping up with most of the aftermarket (slow performer if you will).
One thing is that it's hard to find a performer rpm manifold single or dual plain that has the spreadbore pattern for 1987 or later heads with egr that will fit under the stock hood of the 25th ann. rag top rs.
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
If you intend on a larger than stock TBI unit you will have to bore the edelbrock TBI intake holes to 2". This cam be done but it may be easier and behoove you to just go with a single plain intake and adapter plate as you have been inquiring.
monte87cortez
09-26-2015 08:10 PM
