Rev Limiter?
Car: 92 Camaro Heritage RS
Engine: 5.0
Rev Limiter?
do our cars have rev limiters? if so what rpm and what should we consider a true redline for our cars causse 5 g's seems low
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
there isn't one from the factory, beyond the rod bolts, and valvetrain.
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Rev Limiter?
Car: 1992 Camaro RS
Engine: 305 L03
Transmission: Borg-Warner WC T-5
Yeah, like the other guys said, and even if you do go crazy with the revs, you likely won't do any real damage because you will float the valves.
Car: 1983 G20 Chevy
Transmission: 4L60
I have seen someone take a high mileage L05 in a tahoe start it, stick a brick on the pedal, and leave it, 30 minutes later the engine was still runing. After 45 it ran out of gas. Those don't have RPM limiters. It was simply limited to about 6,800 rpm due to cam timing, head, valve float, and exhaust flow. Engine just would not die. When the engine was torn apart the bearings were even in good condition.
If you really want one I think it is possible to program one in. I'm sure Dewey and RBob know more about this than I do though.
Car: 1990 Camaro RS
RBob or Prevost (off the top of my head, I don't recall who it was) wrote a patch for a rev limiter, it converts the speed limiter, to work as a rev limiter. I have it around here somewhere...I can look for it and post it when I find it.
Car: 85 T/A, 92 Rs
Engine: L98:D,L03:<
Transmission: 700r4x2
Axle/Gears: 3.23 bw, 2.73 10 bolt.
hah, well i might caution agains going too high, you can blow the dang AIR pump and lose 3 freaking tenths in the 1/4.
been there done it
been there done it
1 Post
Car: 1992 Z28 (Heritage Edition)
Axle/Gears: 2.73 Posi
Re: Re: Rev Limiter?
Originally posted by ShiftyCapone
I believe it was JP who set a rev limit of 1500rpm and a speed limit of 25mph for his vallet setting. Ha.
RedLeader289
05-28-2019 01:47 PM
