edelbrock TBI multi-point conversion
Old 02-24-2005, 04:58 PM
RED92BIRD305's Avatar
Car: 92 firebird and 95 trans am
Engine: LO3 and LT1
Transmission: 700R4-4l60E
the Edelbrock3501 EFI kit for TBI small blcok chevys. this kit is described as being for the trucks but would it also work on the f-body engine? i dont really see why not.it also says for 5.7 litre i thougt they used the same ECM,TBI, and what not? if this conversion would work i think that would be a nice way to go
Old 02-24-2005, 05:23 PM
BronYrAur's Avatar
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
The trucks use the 7747 ECM, we use the 8746 (or 8063 '88). Whatever PROM they sell with the package won't match up, also the trucks had bigger injectors and a 350 to further throw off the tune. I'm not really sure what Edelbrock includes in that package.
If it were me and i wanted to go multiport, I'd just get a good carb manifold, get injector bungs welded in, use the TBI without the injector pod to meter the air and run a 7730 ECM.
Old 02-24-2005, 05:26 PM
Engine: LO3 and LT1
thats kind of what it is it is a manifold that uses the stock TBI but runs a fuel rail and multi pouint fuel injectors. i will try to post a link to it
Old 02-24-2005, 05:32 PM
Engine: LO3 and LT1
http://store.summitracing.com/largei...?part=EDL-3501
Old 02-24-2005, 05:44 PM
BronYrAur's Avatar
Engine: 305 TBI
Yeah I've seen it before, I'm just saying it'd probably be cheaper and more modifiable if you did what I said. You can pick whatever intake you want then (I dont know how well that Edelbrock manifold flows). Looks like you got a stock engine though, you'll want to beef that up a bit more before something like this is needed anyways. It's a pretty cool setup though, just think there might be more cost effective ways of getting the same thing.
Old 02-24-2005, 05:52 PM
Engine: LO3 and LT1
the problem i am running into is i plan on modifying my engine. if i buy heads i will see almost nothing from the heads until i change my cam and intake manifold and vice versa.
Old 02-24-2005, 10:22 PM
z71stroker's Avatar
Engine: 355 6"rod tbi - in the works
Just email the edelbrock tech department, they were pretty helpful, unlike some other companies. I am going to run the #3506 kit for tbi mpfi conversion for vortec heads. I have a 94 tbi truck though. It's a single plane manifold too : )
going on a -
355cid
scat 4340 6" rods bushed
speed pro hyper flattops
pro topline vortec heads 3/8 screw in studs 120lb springs
9.9:1 CR
I have a comp cam 268h, think i'll be switching to one of the xtreme energy 4x4 cams
Bubbajones_ya
07-06-2024 08:32 PM
LittleFranks
10-07-2015 11:26 PM
Glowsock
09-11-2015 11:09 PM
toronto formula
09-10-2015 07:31 AM
Wylecoyote08
09-08-2015 08:26 AM
Quick Reply: edelbrock TBI multi-point conversion
