Throttle Body rebuld kit
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1992 Camaro Z28
Engine: 5.7 TPI L98
Where is the cheapest place that I can find a throttle body rebuild kit?
Car: 1992 Camaro RS
Engine: 305 L03
Transmission: Borg-Warner WC T-5
At your local Pepboys, Autozone, or Advanced Auto...I bought my GP Sorenson rebuild kit at Advanced and it was cheap and good.
I just bought one. They should be in stock at Autozone
https://www.thirdgen.org/techbb2/sho...hlight=963013A
Engine: 5.7 TPI L98
Ok, I got a kit from pepboys and the whole thing is taken apart. Is there any way that I can clean my injectors. I am going to use acetone to clean everything, but I don't know if that will messup the injectors.
Engine: 5.7 TPI L98
Come one guys I don't want to mess anything up inside of the injectors if acetone will do that.
1 Post
Car: 1991 Chevy Camaro
Engine: 305 TBI
I would just leave the injectors alone for now. The only real way to clean them, that I know of, is to send them to a specialty shop and have them run through an injector cleaner (this is NOT the injector cleaner you pour in your gas tank). But, I'm no expert on this sort of thing.
Engine: 5.7 TPI L98
Wow, there was so much black gunk in the thottle body. It idles and accelerates much better now. And the gas pedal doesn't stick anymore!!
![good job!](https://www.thirdgen.org/forums/images/smilies/goodjob.gif)
Re: Throttle Body rebuld kit
hey whats up ben,im working the same color camaro but this has t-tops,its my girl car.that info about rebuliding the throttle body was right on time.she was having a problem with hers.it was dumping to much gas due to the regulator was stuck.when i change the oil it was full of gas..i mean alot of gas.so 2morrow im going out to buy the kit.what the asking price for a new one,is way to much for me..im going try rebuliding.thanxs again.you did a damn good job on yours once i get hers right i will put up a picture.take care
1 Post
Car: 92 Camaro RS
Engine: 5.0 TBI
How much trouble is it to do a rebuild on a tbi? My TBI could probably use it, plus my gas pedal does stick sometimes.
Terrell351
06-13-2021 01:13 PM
mdtoren
08-16-2015 05:45 PM
