Flat pistons or not???
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Originally posted by dimented24x7
Theyre dished pistons with reliefs. Not that thats necessarily a bad thing unless you need lots of compression.
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Heh, I always thought of them as basically flat tops but evidently any sort of slight dish is a dish.
I dont think theyd cause too much of a problem unless your running a cam with some serious overlap or something. What was the LO3's compression? Around 9.3:1 or so?
Car: 88 Camaro SC
Engine: SFI'd 350
Well, if you have a good LO3 shortblock then just bolt all the parts (heads, cam, etc.) from the LB9 and you should be good to go.
Car: '90 RS
Engine: 377 LSX
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
Whats funny is I don't see how the LO-3 was rated at 9.3-1. I had a stock H.O. 305 in my monte and it ad true flat tops, No little ridge around the edge. With 58cc heads it was rated at 9.5-1. I know for a fact that those pistons are worth at least .5 to .75 points of compression.
LT1Formula
10-08-2015 09:34 PM
skinny z
10-05-2015 07:23 PM
