93-95 tbi truck differences
I am looking at a Weiand blower right now for my car and they make a kit for the 93-95 tbi trucks which they say is a close bolt on. What is different about them from our cars? Are the serpentine setups the same, the fuel lines, throttle body, etc???
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
The TBI unit found on the 350 and 305 trucks are identical to ours as far as locations are concered. That means the fuel lines along with every other sensor come out of the TBI in the same manor. The serpentine set-ups are slightly different. My dad and I just sold our 305 TBI truck and I only spent limited time under the hood so I am trying to remember. I did notice that it had no sort of AIR or AIR pump but did have the typical truck mechanical fan and shroud that stuck up pretty high. There is basically just a tremendous amount of room under the hood of any truck and I think that is where the difference lies. That and the extended hood clearance that we can only dream of prevent using that blower without a little coaxing and relocating.
I have a Harwood 3 inch cowl hood so I don't think hood clearance will be an issue. Are the fuel pressures the same? I seem to remember the later model tbi trucks ran on higher fuel pressure. Anyone have any pics of the weiand tbi setup? I'm thinking of running an fmu for the extra needed fuel and I will run a small shot of nitrous for an intercooling effect.
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Car: 91 firebird
Transmission: t-56
the truck serpentine set places the A/C and alternator closer to each other and use steal unlike the fbody with two aluminum peaces
Car: RS
Transmission: 4L60
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
I have been searching online for a while now trying to find some good tbi truck sites to get info from. Can anyone help me out please?
I have a little more info and I am really serious about getting the blower now. It would be a sweet setup to run that with about 6 psi of boost and a small shot of nitrous at the track. I believe I could pull some pretty insane times with that combo. I have a couple pics of the kit, but don't know how to post them.
Car: 1990 Chevy 454SS
Engine: 454
Transmission: TH400
info
There are a couple of guys running chargers on www.454ss.com, some whipples, vortechs and even a couple of paxtons.
They might be able to help with info.
Car: 90 454SS
Engine: 454 TBI
Transmission: TH400
Originally posted by vic_V8
www.fullsizechevy.com
There are some heavy TBI bashers there
Engine: 454
Transmission: TH400
Originally posted by va454ss
He said good TBI truck sites.
Well.. You have a point there.
evilstuie
01-09-2020 08:29 PM
junkcltr
08-02-2019 11:12 PM
1995, 454, 9395, 95, bolt, carb, difference, fullsizechevycom, serpentine, setup, tbi, trabsmission, truck, trucks
