porting vortec heads and then installing them on a 327 V8 tbi in 1 1989 k1500 4x4
Old 08-23-2004 | 11:50 AM
1989RCT2004's Avatar
I plan on installing vortec heads on a 327 Chevy using the factory TBI and installing the motor in my 1989 4x4 that currently has a 4.3 liter vortec. Everything that I have read says that this is an easy swap and everything should bolt right up.
I ordered the Heads from JEG’S for a little over 500 dollars for the set. After weeks of research by reading everything I could get my hands on dealing with porting and polishing cylinder heads. I applied what I had learned and worked a set of 882 and 193 Chevy heads. I wanted to get some experience before I attempted porting the vortec heads. Once completed, I used a hacksaw and cut the heads in half. I closely inspected the walls to see just how close I was to going into the cooling ports. I finally felt confident enough and I pick up a Dremal and started to grind the vortec heads. I numbered and removed all of the valves. My next move was to grind the valve heads down on two old valves. I then placed them into the chambers to protect the seats and started to polish the combustion chambers one at a time. I didn’t remove much metal just enough to smooth out the surfaces, after all I do not want to change the compression ratio. I figure I will have ten thousands shaved off just to keep the chambers at 64 cc. My next step was to grind down the exhaust bosses, port the bowls, and to remove the rough casting surfaces in the exhaust ports. I did not remove very much metal on the short side, just enough to get the surface smooth. I also didn’t gasket match the exhaust ports I retained the stock size. From there I went to the intake ports and gasket matched them. I did not remove any metal on the floor or the sides of the ports, once again just enough to smooth out the surfaces. The entry points on the intake were opened up quite a bit on the roof and on the short side of the intake. All of the walls were made the same and they all have the same matching angles and bevels. I then went to work on the intake bosses and ported the intake bowls. I proceeded to polish the exhaust ports, and then smooth out the intake runners. I did not finely polish the intake runners and bowls. I have heard that that would cause the fuel to puddle up. I ended up with mirror finishes on the chambers and in the exhaust ports. The very last thing I did to the heads was to smooth up the inside and underneath, all of the places where the oil likes to puddle up, clog up, and solidify after several thousands miles of use.
Take a look at the pictures and see what I have done to these heads and please give me your honest opinions. Has anyone swapped a 4.3 liter for a V8? I plan on keeping the stock TBI system, but I am going to installing the bigger TBI from the 350. I want to run full length headers with after market Catalytic converters with duel exhaust. Retaining the stock engines EGR valve, Oxygen sensors, and smog equipment. After all I need to keep the motor smog legal for New Jersey vehicle and emissions inspection
The TBI manifold for the vortec is very pricey. I have seen where some guys have used an after market vortec four barrel carburetor intake (which is half the price of the TBI intake) and made up a plate that bolts the throttle body to the intake. Would this cause the engine to run improperly or rob the engine of valuable torque and horse power?
Attached Thumbnails porting vortec heads and then installing them on a 327 V8 tbi in 1 1989 k1500 4x4-mvc-377s.jpg
Old 08-23-2004 | 12:06 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
Heads look good.
As for manifold, an aftermarket single plane 4bbl, with adapator will be you best choice.
Old 08-23-2004 | 12:08 PM
steve8586iroc's Avatar
As you have noticed the vortec heads do not have exhaust crossover passages so to run an egr system you will have to use an egr kit that plumbs the gasses externally. Scoggin Dickey Parts Center or SDPC carries what you'll need to make the egr system work.
Steve
Old 08-23-2004 | 12:17 PM
vortec heads
Thanks Guys, I spent about 45 hours on these heads. Back to the intake manifold, I was thinking that if the TBI unit would not work properly then I could always fall back on the four-barrel carburetor.
Attached Thumbnails porting vortec heads and then installing them on a 327 V8 tbi in 1 1989 k1500 4x4-mvc-371s.jpg
Old 08-23-2004 | 01:16 PM
JR92z28's Avatar
Car: 1994 Z28
Engine: 5.7 LT1
I have some questions related to this matter.... (not trying to jack the thread )
1. Which Vortec heads don't have the passage for the EGR gases?
2. If someone bought a pair of Vortec heads and without the EGR passages and an intake with no egr, would that work? Of course tuning the the chip and disabling it there...
3. How much would you have to mill them down to fit a sbc 305 or 327?
Thanks,
By the way heads look nice, and the Carb intake which is cheaper is the way to go...
Old 08-23-2004 | 01:19 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Im using a carb manifold with an adapter as well. Works fine other then the loss of clearence with the hood due to the adapter plate. BTW, this is a thirdgen site so for future reference jsut ask questions about your tbi, motor, etc and avoid questions related to your vehicle. Non thirdgen posts are typically locked. I think we can pretend that your running a thirdgen if we dont see otherwise.
Old 08-23-2004 | 01:21 PM
Car: 88 Camaro SC
Engine: SFI'd 350
Thanks,
q's 1 and 2,
Yes, the vortec heads didnt come with egr passages cast into them. Hed have to use a manifold that accepts external plumbing off the exaust for egr. IIRC, GM makes such a manifold.
EDIT: You can jsut not run egr by disabling it in the calibration. The ecm adds additional spark and pulls fuel when the egr is active.
Old 08-23-2004 | 08:03 PM
25THRSS's Avatar
Looks good. You could even go as far as a 3 angle "valve job" on the spark plug portion of the combustion chamber, have bigger valves installed, and go ahead and gasket match the exhaust ports. A set of heads on another car of mine have many of those tricks and flow 296 on the intake.
Old 08-23-2004 | 08:49 PM
cali92RS's Avatar
Car: White KSwisses
Engine: 5.3L Gen III
Thanks,
Since Dimented answered Q's 1 & 2, I'lll tackle 3.
The heads dont have to milled at all to fit either the 305 or the 327. It all depends what compression ratio u want. When you have a combustion chambered milled, you increase the compression ratio. But whether your pistons are dished, flat top, or domed effect your CR also.
With stock 305 piece-of-crap-dished-pistons, people tend to mill the combustion chamber to 58cc or smaller to keep or increase the stock compression ratio (which i think is 8.5:1, although i might be wrong). If your building a 327, it all depends on the pistons youll be using.
Old 08-23-2004 | 11:44 PM
25THRSS's Avatar
stock compression ratio is 9.3:1
InfernalVortex
04-20-2021 11:31 AM
FormulasOnly
07-23-2018 08:47 AM
plm99
Southern California Area
11-16-2015 05:21 PM
Quzyle
10-15-2015 03:35 PM
BLK87Z
09-18-2015 11:29 PM
Quick Reply: porting vortec heads and then installing them on a 327 V8 tbi in 1 1989 k1500 4x4
