Huge complaint about the Turbocity carb adapter
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
Yeah this should probably go in the aftermarket review board but since TBI guys are the only ones concerned with this product I'll post it here.
I checked all over for a vacuum leak, and I even cleaned my idle-air-control valve because I was idling around 2,000. It turns out that the bolts are longer than the adapter; the damn plate got warped and I drove the bolts into the manifold, lifting the plate upwards causing a huge vacuum leak! I had to go to the hardware store and buy shorter 2" bolts instead of the given ~ 2 3/8" ones. I marred the manifold and almost stripped a bolt hole off the manifold. There should definitely be a warning on the box. I can't believe I didn't catch this beforehand. I was far too excited to get the damn car running, I never thought about it.
So in the future, if you're using a carb manifold with a TBI, either use washers to space the bolts off the TBI or go buy shorter bolts.
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
i had the same thing with my holley, luckily i caught it before assembling the everything, and being unique head design on the bolts, i ended up actualy cutting them, instead of buying shorter ones.
Car: 91 RS
Transmission: TH 700 R4
Hmmm.. good to know since I just bought one but haven't put it on yet. I thought turbo city would get it right for our cars if anyone did.. this is disapointing news.
Car: 1990 caprice 9c1
Engine: lo5 350 tbi with 416 heads
how is the performance with the 4brl mainifold and adapter VS the edelbrock TBI manifold?
Car: 1992 Firebird
Engine: forged 357
sreZ28
10-22-2015 08:21 AM
