Marbles in a metal pan
Ever since I got my camaro, there's been a nasty rattling noice at idle. I could never put my finger on it, but I thought it had to be something on the serpentine belt. So the other day, I took my car to the shop to get a starter re-installed that they screwed up. They told me it was the water pump bearings. So a couple days ago, I replaced the water pump.
THERE'S THAT DAMN RATTLING AGAIN!!!! whenever I idle, it sounds like a bunch of marbles being rolled around in a metal pan.....It also definitely sounds like it's coming from the front of the engine bay where all of the pulley's are.
My girl's 89 RS has the exact same noice and so do a couple of my other friends' with thirdgens. Anyone got any experience with this?!
Thanks!
Thanks!
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Are you sure the engine is not knocking? Your description sounds like it to me. I would check your timing and maybe bump up your ocatne a bit the next time you are at the pump.
hey thanks for the reply man,
No I realllly don't think it is. It only happens sometimes and in odd intervals. and I use 89 octane so :/ It definitely sounds like a bearing of some sort.
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Knocking is REAL hard to confuse with a marble in a can type of sound. Either you hear the marbles or you hear a dull thunking. If it's marbles, I would say detonation.
Just out of curiousity, hand rotate the engine to TDC according to the timing marks. Once at TDC, remove the distributor cap so you can view the rotor. Now rotate the engine backwards so you can see the rotor rotate in the opposite direction. The responcse between you rotating backwards and the rotor turning should be almost instantaneous.
Location: "When the going gets weird, the weird turn pro." -RIPHST
Car: 1991 RS
Engine: 383TBI Fastburns and 2"TB
Transmission: T56 held up by Spohnstuff
Idler bracket/pulley
Power steering pump
AIR pump or
Altenator.
Crank Pulley loose(?)
Look for rust or dust buildup to help determine which one it is-
I'd start with the idler pulley-
Best-
S-D
Power steering pump
AIR pump or
Altenator.
Best-
S-D
1 Post
Car: 92RS
Engine: 357
try taking the belt off and run it for a few seconds and see if the noise goes away. If so try turning over your accesories and see if they seem normal.
Car: 1991 RS
The idler assembly is the thing that tensions the belt.
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Originally posted by swerve-driver
Excellent idea.
Excellent idea.
Car: Turbo Buick
Engine: 3.8 V6
have any of you ever heard a motor knock at idle?
lets see a show of hands..
anyone?
one of your accessories probably, AC compressors tend to make that noise, is your AC on when you hear it?
anyone?
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
My car would knock at idle when I had a serious timing problem 4 or so years ago. An old company vehicle I used to drive (4.3 TBI) would knock at every sinlge rpm including idle. It was shot, but ran. Cars that diesel when shut off are also knocking at idle.
1 Post
Car: 92RS
Engine: 357
Originally posted by ShiftyCapone
I wouldn't do this very long.
If I was doing it I would have someone else start the car so it wouldn't take as long to start and stop.
skinny z
10-05-2015 06:23 PM
sjorgens
10-01-2015 07:54 PM
