New hood, new tbi mod
Car: 91 Camaro RS
Engine: TBI
Seeing as how i went form the stock hood to the 4" cowl i have a huge amount of room to play with. Before i had a 14x3 k+n open element so my dad had a 14x4" purolator from pep boys that he has for the ram air on his truck, I threw it on and put up a longer stud. Still have a ton of room underneath. Runs alot better low end is a slight better but when you are jsut cruisin and get on it it really pulls harder. So heres some pics for your enjoyment.
Can i put on a 14x5" filter or will the 5" tall one bog the motor down any. I have the room.
THis sounds so much better nice and loud.
I'de bet it's all in your head. You're not gonna gain much or lose anything from changing filter heights. If you really want to you can invest in an Xstream filter top to take advantage of the cowl hood.
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
is already getting everything he will out of the cowl. the only way for more, is to make a sealed filter housing, and make it true cowl induction.
I agree with it being in your head. a 3" paper element will flow enough air for TBI, what good does getting more through the filter do, if it can't get through the TB.
Not really, if you look at the second pic, the top of the filter is level with the very bottom of the hood, and is taking in all it's air from the sides which is below the hood, so basically the cowl hood isn't doing much, if anything right now. If he was to use an xstream filter top he would be able to pull some air in from the top where the cowl would be providing cooler air. Or he could just get a high rise manifold with a thick spacer and then he might actually need the hood. Either way, the placibo effect is going on here big time. BTW, where did you get the longer stud from?
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Ditto on the placebo effect. If anything you are feeling a difference from a lighter front end from that hood. Even if you made a true cowl induction you can only get so much air into the TBI unit as dewey described. The only way to get more in is through forced induction.
Car: 91 Camaro RS
Engine: TBI
The stud was from my dads 91 suburban becasue he got a new one when he put the ram air on. It sits up just inside the cowl when the hoods closed not much into it jsut a tad. I figure a spacer and the xstream lid to get up into the cowl and i also want to do the injector spacer. Anyone have the weight of the stock hood on these things? I know the hood is nice and light but i drove around with it for two days with the 3" filter. It might be in my head i got some weird stuff that goes on in there
However i am a example of publik edumacation so can some one elaborate on teh placebo affect. I think i know what it means but wanna double check.lol
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Car: 1990 Camaro RS
It is a medical term, when testing drugs, they give out 'placebo' pills (sugar pills) and also real pills. they do this to determine if the effects seen by the patients are in their head, or the medication.
Car: Badass 1991 Firebird
Engine: Screamin' 305 TBI
Axle/Gears: 2.73, 3.42's waiting to go in!
In my humble opinion, a huge filter is the next best thing to no filter--so a taller element is going to allow more air. My open air element makes a very loud induction sound at high rpm, almost whistling, and it's just a paper filter--definitely helped. I plan to use a K&N filter next, because it's cloth and flows better. Not only that, but the ECM will add fuel to compensate for the increased airflow. So I'd be willing to bet this man is experiencing some real gain, if only a small gain. Plus the burly induction noise is nice.
My open air element made a huge diff. These motors are just begging for higher flow in all departments. For those about to rock their TBI, I salute you. Mine already snorts pretty good, and it's stock.
Oh yeah, totally agree on fabbing an airbox to take advantage of the cowl hood. There are some cool ones on these threads.
Rock on with your huge filter dude! And fab up an airbox for cold air, that's supposed to really boost performance as well.:rockon:
Car: 1990 Camaro RS
only so much air can go through the throttle body, no matter how big the filter is.
its like a funnel, not matter how large the top is, only so much can go through the bottom, no matter how much larger you make opening at the top, it doesn't it make it get through the bottom faster.
and the ECM does not correct at WOT.
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Originally posted by 25THRSS
I wasn't saying to get the top for more air flow, simply for cooler air because it's closer to the cowl where it might be able to take advantage of it.
You're probably right, but it's in the every little bit helps catagory, besides the Xstream top just looks so damn cool, lol. A little off topic, but is the plastic piece infront of the radiator, surrounding the hood latch, needed? I always use it to put all my tools on, but does it actually serve a purpose?
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
No, not the piece that holds the radiator in place, that's the shroud. The plastic piece I am talking about is directly in front of it. The lower hood latch is directly in the middle of it. The only thing I can think is it might have something to do with cooling, but I don't think it has a purpose besides looks. Anybody know?
EDIT: This piece
https://www.thirdgen.org/techbb2/sho...diator+plastic
EDIT: This piece
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
Well, that's where the TPI ducts go because there are two filters on each side of the latch. I'm going to guess that since the TBI cars didn't utilize that kind of intake system they just covered up the wholes with a flat black plastic piece.
Engine: 305 TBI
I don't think so. I think just to cover it up so there's no gaping hole there. Unless there's some kind of airflow that goes up in front of the radiator in that space and that plastic kind of "holds" the air in there. Just a thought.
Car: 1990 Camaro RS
no it doesn't serve a purpose. firebirds don't even have one.
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
EDIT: This piece
EDIT: This piece
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Firebirds don't have one, but they have sheetmetal in place. The only thing I could think of is it may have something to do with air flow as mentioned before. I didn't mean to hijack this thread so I apologize.
Car: 1990 Camaro RS
I think it was purely apperance related. i doubt it serves any functional purpose.
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
I hate to let you all down but it does serve a purpose. Just like the dam on the bottom of the radiator this plastic cover makes sure all air moves thru the radiator. As most of us know we need all the air we can get thru the radiator and thats still not enough. I would not remove it unless to replace it with something else.
Steve
Steve
Car: 91 Camaro RS
Engine: TBI
I've considered making up a nice smooth stainless steel plate for that littel cover to clean it up a littel then maybe have my buddy etch like camaro or rs or something into for somethign real unique.
I think it does help direct teh air flow through the radiator
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Steve
Steve
Car: 1990 Camaro RS
the hood closes so tight in there, i doubt it makes any significat diffrence. the holes in the one on my car, have got to let as much air through, and the small gave between the hood and the core support.
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Car: 1990 Camaro RS
come on, next we can talk about the light under the dash, that shines on the ashtray. thats always fun.
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
What about the 3 screws that hold on the stereo face plate and the mystery ghost fourth screw that is conveinently tucked under the gage cluster part of the dash? We really need to get back on topic here
Car: 91 Camaro RS
Engine: TBI
Originally posted by ShiftyCapone
I never thought about that....[me scratching chin]
I'm working on some plans to fab up a functional box to make this hood really work.
Black89TA
Exterior Parts for Sale
07-23-2016 10:42 AM
