Homemade FPR?
Old 06-23-2004 | 05:10 PM
92MaroRS's Avatar
Car: 1992 Camaro RS 25th Aniversarry Edition
Transmission: TH-700-R4
Axle/Gears: 10 bolt with 3.23's and SLP Posi.
Homemade FPR?
can someone post pics of what they did or just general pics of this area of the TBI for making the Adj. Fuel Pressure Regulator.
https://www.thirdgen.org/newdesign/tech/tbi-afpr.shtml
Old 06-23-2004 | 07:32 PM
92MaroRS's Avatar
ANYONE
Old 06-23-2004 | 07:36 PM
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
I don't have any pics but I have done that mod. Do you have a question about something or just looking for pics?
Old 06-23-2004 | 08:38 PM
92MaroRS's Avatar
just trying to make sure i do it right. any tips that the tech article doest mention?
Old 06-23-2004 | 11:04 PM
Z28GEN3's Avatar
the only thing you drill out is the dinky cup at the base of the reg. i believe 3/8 drill bit is plenty big. and just slot the screw though there are a number of different ways to make it an adjustable reg, so you can adjust it w/o even removing the tower.
Old 06-24-2004 | 05:50 PM
weberusn's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Does this make it so that you can manually adjust the pressure, or is it a vacuum thing. Also how high can you get your fuel pressure with one of those?
Bill
Old 06-24-2004 | 08:12 PM
Benm109's Avatar
Engine: 305 TBI
If you do that mod, yes, you do have to manually adjust the fuel pressure. You can buy a fuel pressure regulator that runs with vacuum from TDS (sponsor at top of page) but you still have to manually adjust that one, too. The homemade one is cheaper, of course. I am not sure how high you can get the pressure but if you bump it up too high it will have negative effects (bigger is not always better).
92MaroRS-I have one tip for you. After you get done with the FPR and turn it 180 so that you can see how high or low the cup is with the TBI on the car, make sure you grind a little bit off of the FPR housing because it will not seat flush since it has been turned. If you don't know what I'm talking about now, don't worry, you will when you do it.
Old 06-25-2004 | 12:01 PM
Z28GEN3's Avatar
finished part
92-Formula
12-12-2015 10:34 PM
mike22115
09-28-2015 04:49 AM
Lmancha96
09-25-2015 08:11 PM
Strick1
09-04-2015 07:11 AM
Quick Reply: Homemade FPR?
