TBI injectors won't fire
Car: 1991 Camaro RS
Engine: LO3 TBI 305
Transmission: 700R
I have a 1991 camaro RS with an '88 tbi 305 motor and wiring harness. The car was running great, but now the injectors won't fire. The car has 14psi of fuel pressure and it has spark. I have changed the ECM and the injectors, but still nothing. It will start if I put fuel into the throttle body, but only until that fuel is gone. What do I need to do to fix my car?
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
if you have VATS, that's most likely the problem.
Car: 1991 Camaro RS
Engine: LO3 TBI 305
Transmission: 700R
yes all the fuses are good, but I'm not sure about the VATS.
shouldn't the starter not work either if the VATS is defective?
Car: 1992 Camaro RS
Engine: 305 V-8
Your right about the vars....I just got the keys made for a 1991 rs i bought and when the codes in the vats is wrong the starter wont even turn.
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
What ECM did you swap in when you say you changed it out? and did you use the chip in that one or swap it from the 88 ecm? I'd check the connection wires on top of the injectors too see if they're still consistent.
1992rs/ss
16
01-28-2016 09:58 PM
92camaroJoe
08-13-2015 06:07 AM
