So I got my Dual Snorkel Air Cleaner Today....
1 Post
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: WC T-5
I got my dual snorkel air cleaner today and I relized this thing flows like crap!
First of all its drop base, so that means you have to use that spacer ring around the TBI wich restrickes air flow.
Second, there is a flap inside the snorkels that also restricks air flow. Why is this thing there?
Becuase of this poor air flow I am thinking about either selling it, or modding it.
If I mod it, I will convert it to flat base, gut out the flaps, and get a different lid so I can use a bigger air filter.
What do you guys think about this? Has anyone done this mod? Or should I just sell it and keep the open element?
Pics:
<a href="http://chrysalismusic.net/MVC-578S.JPG">http://chrysalismusic.net/MVC-578S.JPG</a>
<a href="http://chrysalismusic.net/MVC-579S.JPG">http://chrysalismusic.net/MVC-579S.JPG</a>
Pics:
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: So I got my Dual Snorkel Air Cleaner Today....
I would keep it and modify it a bit. You can cut that flap out. That is for the thermac device but I am sure you have gotten rid of it if you have an open element. I have never seen the assembly up close so I cannot compair it. It is hard to beat the ol' non drop base open element. Personally, I would only use the dual snorkel for looks.
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
If you already have a K&N open element and K&N lid I wouldn't switch over to dual snorkel. You aren't going to gain anything and you probably dropped a few bucks on that K&N setup.
Car: 1990 Formula Firebird
Engine: 305TBI w/ Functional Sport Hood CAI
Axle/Gears: SLP Posi and 3.23 Gears
Possibly, I've heard dual can possibly give more hp than Open due to the colder denser air. But havent seen any dyno runs proving this. I heard cowl induction set up on the birds is the best way to go.
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
1 Post
Car: 91 Camaro RS
Engine: 305 TBI
My theory is that a lot of hot air is better than a little cold air.
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Originally posted by johnjm22
Did you see the pics I posted of it?
But If I converted it to flat base, used a different lid w/ a bigger element, and gutted the flaps, Do you still think an open element would be better?
1 Post
Car: 91 Camaro RS
Engine: 305 TBI
Damn, I wish I could take my car to the dragstrip and do a dual snorkel vs. open element test. It would finally settle this dispute!
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
1 Post
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
1 Post
Car: 91 Camaro RS
Engine: 305 TBI
Re: Re: So I got my Dual Snorkel Air Cleaner Today....
Originally posted by GASGZLR
I have one of those TBI gold rings on my carburetor to raise my triangle non-drop air cleaner into the scoop on my hood. I have ran at the track with and without it and it made no difference. I know a carb looks different from a TBI, but I don't think that TBI engines rev high enough or flow enough air to be affected by this little of a change.
Originally posted by ThraxXx
I love that chrome look.
1 Post
Car: 91 Camaro RS
Engine: 305 TBI
Originally posted by azvolfan
johnjm22,
Here is my set up. It's plated in black chrome. I'm quite happy with it.
johnjm22,
I'm curious why did you choose dual snorkel over open element? And have you done any modifactions to get it to fit?
Car: currently thirdgenless!!!
I like the look of the dual snorkel. When I decided to change to it I knew right away that I would chrome it.
No modifications needed. It fits right over the throttle body.
Car: 89 Camaro RS
Engine: 305 TBI
Mine is still black.. I removed the flame arrestor from mine, cleaned it all up, drilled and mounted the sensor that goes in it.. I noticed a slight improvement over the stock single snorkel.. it sounds better also.. when you compair the two, the dual has way more volume in just the one side.. then you double it.. equals more cold air into the engine.. I like it. I kept the functional thermacs. and the original TBI lid.. the one that actually went with it didn't fit.
1 Post
Car: 91 Camaro RS
Engine: 305 TBI
Originally posted by FastElectrics
[B]
[B]
Why did you leave your thermac device intact? Thats also hurts air flow.
The overflow tank is not removed. It is on the other side. I guess that is one mod I had to do. I no longer have a washer tank. I also took off the diverter valve. It is kinda in the way but it will work with it on.
I left the spacer ring on because I think it may hit the distributer if I take it off.
As far as the thermac, I didn't care about it. Even with the thermac it flows better than the single snorkel and probably more than a 450 cfm or so TBI can handle.
My 5.0 decal was already on the assembly.
As far as the plastic scoops and hoses, I got them all but the local Chevy dealer except the drivers side scoop. The stopped making it and I believe the have since stopped making all of them. So I picked it up on the internet. They are on e-bay every now and then. Expect to pay dearly for it. I bid $182.50 for one and got out bid.
1 Post
Car: 91 Camaro RS
Engine: 305 TBI
I don't think people realize this, but you can buy the hoses and scoops brand new from year one. The hoses are like $20 and the scoops are like $12.
yearone doesnt have them, i posted that awhile ago thinkin they did.
I contacted an aftermarket company that makes dual snorkel cleaners and asked them how much they were selling the LH and RH snorkels for and they said $80-90 each. on OEM parts, they supposedly had a large supply of Snorkels but they werent gonna let em go cheap. yea you can buy the regular snorkels real cheap but they arent the same part # as the ones for the L69 H.O. cleaners those snorkels (like azvolfan) has have a larger opening, and the ducts are larger as well.
1 Post
Car: 91 Camaro RS
Engine: 305 TBI
Drivers side fresh air hose: AC9LH $18.95
Passengers side fresh air hose: AC9RH $18.95
Driver side air cleaner duct: AC8LH $11.95
Passengers side air cleaner duct: AC8RH $11.95
Air Cleaner wing nut: AC849 $2.95
Air Cleaner Duct Screw: AC855 $1.95
Fresh Air Elbow: 3404N $10.95
Straight from Yearone's Catalog:
The L69 305 H.O. engine option in 83-87 camaros and firebirds made use of an effective dual snorkel air cleaner and cold air assembly. We offer this equipment seperatley for owners of L69 cars who may be missing certain peices, and also as an effective retrofit kit for owners of LG4 305 4bbl cars and Lo3 TBI cars.
Wrong. Yearone does have them. Here are the part numbers:
if you goto their website yearone you will see they no longer have them. the only ducts they have are the replacement ducts for the stock replacement cleaner.
RAMAIRBOX this is the aftermarket company, since it was about 6 months ago when i contacted them i doubt if they have the OEM ducts. looks can deceive. "Part # 14070917LH / 14070918RH Intake size 4" oval Exhaust size 4" flat Length 14" Material Plastic" at bottom of page.
link 1
link 2
link 3
Guest
Posts: n/a
I got the last 2 right side scoops that RAMAIRBOX had
in conjunction with my dual snorkel air cleaner I use: 84 El Camino K&N filter (taller) and the cleaner lid from a '79 corvette.
For spares:
I also have the dual snorkel cleaner from said vette and a right side scoop for the system, also a modified left side scoop from the LO3.
For spares:
I also check with YearOne when I was doing the dual snorkel install, and they did NOT have them. Even though they said they did.
1 Post
Car: 91 Camaro RS
Engine: 305 TBI
I know this. the catalog is not upto date, if it was everyone in their brother would have these parts. you must have the same catalog i have that lists them.
link 1
link 2
link 3
link 1
link 2
link 3
Hotrodboba400
12-10-2019 07:07 PM
IROCZDAVE (88-L98)
09-02-2015 08:49 AM
IROCZDAVE (88-L98)
09-02-2015 08:43 AM
