Whats the size of gas tank in a 92 RS and how much mileage should a stock rs get??
Car: 1992 Camaro RS
Engine: 305 V-8
Hello,
I was just wondering how big is our gas tank?? How many gallons will our stock tank hold?? and also what mileage should a stock 92 rs get on highway and city.
1 Post
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
The Tank is 15.5 gallons. City is supposed to be something like 17 MPG, while HWY is supposed to be something like 21 MPG. I've never got either though.
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
The tank can hold 15.5 and about another half gallon in the neck if you really fill it. Your owners manual will have all the fluid capacities for your car. Mileage depends on the state of tune of your car. With only a cat back and open element I could get 31mpg all day long on the highway.
Car: 89 RS
Engine: lo3
Transmission: 700R4 w/ B&M shift improver
Axle/Gears: 3.27 9-bolt posi
31 mpg?!??! man, you guys are nuts. I wish i could get that, maybe after my full exhaust install....not likely...
I usually get 17 mpg, and 14 gallons in a tank, although im sure thats b/c i never run it totally dry.
My best ever was 20mpg, and that was all highway, never broke 2000 rpm's the whole tank, never used the AC, and always had the windows up on the highway (dont laugh, it does make a difference). Gotten as low as 11-12 before, that was a fun one.
-chuck
-chuck
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Well a lot of the difference is in the FP settings. GM did not have a standard stock setting for these cars and some got higher than others. That combined with a good tune (meaning tune up) can produce amazing mileage results.
Car: 1992 Camaro RS
Engine: 305 V-8
Everything is still stock in my rs. Is there anything I can do to improve my gas mileage in my little 305 TBI??
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Car: 91RS
Engine: 305tbi
Also what does a "really dooe tune up" consist of. What parts should I replace?
Of course use common sense, if you changed your tranny fluid a few thousand miles ago there is no reason to do it again.
I get from 9mpg up to 22. 9 would be going very slow through backroads, stopping often, i'm talking a 5mph average. 22 on the highway.
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
1 Post
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
I would also like to know, cause my 89 is tuned up and my tripometer doesn't work and the gas gauge fluctuates. I filled it up to the brim where gas was leaking out of the filler neck and the gauge never went all the way full. ??? It only took 13 gallons and the needle read all the way empty when I went to the gas station, as a matter of fact, I took a 1 gallon gas can with me cause I didn't think I was going to make it and it turns out I still had 2.5 gallons left? Right now I am pushing 200 miles on this full tank and I need to know how far I can push it before it goes dry, cause I hate putting gas when I THINK I am empty and then it turns out it only takes 11 gallons.
Car: 91RS
Engine: 305tbi
To put it simply our gas gauges suck. GM probably made them read a little low intentionally so people didn't run out of gas. Ive also heard its bad for the fuel pump to run that low.
How long have you had the car? After you fill it up a few times you should be able to guess fairly closely how much gas you have left.
The fuel pump is cooled by the gas as well, so its probably better for the pump to keep a decent amount of fuel in the tank.
Car: currently thirdgenless!!!
Now that 31mpg that Shifty is talking about is probably gonna be for the TBI and not the TPI. I think the LO3's got better gas mileage. Before the mods I typically got 25mpg in my RS. It's down to about 22mpg's now. But I'm not complaining.
As far as our gas gauges go, if you look at the shape of our tank it is slanted. And I think the sensor in the tank is calibrated to read on a straight up and down level. But since it is slanted there is more area at the top of the gas tank. That is why the first half of the gas gauge moves slower than the second half.
Think of it as a cup that has a smaller bottom than a top. As the fluid tapers down to the smaller area, it looks like it is being used faster even though the flow rate may be the same.
Does that make sense? I think it does.
1 Post
Car: 1991 Chevy Camaro
Engine: 305 TBI
You can also have some fun with our stupid gas gauges. If you take a turn pretty fast the gas will go to one side of the tank and the gas gauge will read really low and then bounce back up again after you stop turning. If you like taking fast turns this makes it even more fun.
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Car: 89 RS
Engine: lo3
Where are the fuel filters? ive heard they should be cleaned/changed. And is that FP regulater free mod worth doing? how do you know you have it adjusted right, or how do you adjust it?
-chuck
-chuck
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
-chuck
-chuck
Car: 89 RS
Engine: lo3
but how do i tell if it is adjusted right? those fuel filters prolly need changing dont they? 100k+ on them. I would want less preassure then there is right now b/c it comes rich from the factory right?
-chuck
-chuck
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
-chuck
-chuck
AkDrifted
08-17-2015 07:45 PM
