sad realization...
Car: 1989 Camaro RS
Engine: 305 TBI
sad realization...
i am new to this forum, but i have had me camaro for about 2-3 yrs, unfortunatly i have not been able to do much to it performance wise, i have installed a k&n filter and a flowmaster muffler, but that dosnt do all that much, anyway, i raced (well started to race) JDizzle the other night, he is running about the same but he has posi-trac as well, right off the line i knew i had lost so i backed off to save myself from some embarassment , everyone said his car is faster than mine, i guess their right, maybe soon ill be able to pull on him, any advice for a 305 automatic would be greatly appreciated
Car: 91 GTA
There are numerous things you can do, IF you are willing to spend a little bit of money, for example here are a few things:
Rear end gears w/ Posi-trac
headers
3" exhaust
custom chip
open element breather
ultimate TBI mods
With this right here, you should be in the mid to low 15's, easy, if you really want to spend some serious money, consider this:
Intake
Cam swap
Heads
This will get you anywhere from high 14's to low 14's depending how your car is tuned.
And of course, if you ever wanted and had the money to spend you could always swap out for a LT1 or LS1 engine, but that is some serious time and money spent. Hope this helps you out!!!
headers
3" exhaust
custom chip
ultimate TBI mods
Intake
Cam swap
Heads
Car: 1987 IROC, 1989 IROC
Engine: built 305, stock 305 tpi
Transmission: Corvette 700r4, t-5
Axle/Gears: 4.10 posi, 3.08 posi
yeah but if you do all that you'll need sub frame conectors and some suspension peices to make sure that power is getting to the ground. and probably bigger tires. just my .02.
What kind of power do you want to make? If you want to have a street car that is reliable and meets smog laws, then keeping from being too radical is what to look at. You already have a catback and air filter, but their are plenty of other things you can buy that will make your engine perform better on a moderate scale. Like ignition, upgrading the throttle body components, headers, and gears. This will keep you in a budget position, but it will only get you so far. If you were interested in buying higer performance internal parts, then your car would also need other things done like tranny and drivetrain upgrades. Along with that, a few suspension parts would be sufficient in helping launches. Hope this helps.
Car: 1990 Formula
Engine: 305 TBI (LO3)
Transmission: 5 speed manual
One of your big problems is that he has 3.73s while you are running 2.73s. If I were you I'd get a nice exhaust and some better gears like 3.42s (3.73s are kinda steep for a basically stock LO3). Open elements are cheap and will help you out on the top end. Check out the TBI forum for more ideas.
Car: 84 Z28
Engine: L69: cam and porting
Transmission: T5, 3.73 rear
Car: 84z, 65 elcamino
Engine: l69 and a hyped up sbc in the camino
Transmission: t5 m21
Axle/Gears: 373s 411s
do all the free mods first. like weight and cheap mods like just overhaul ur engine and stuff or tune it up
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Originally posted by Tom84L69
Nah, the stock chassis is good for about 350 hp in my opinion. A 14 second camaro doesn't need chassis mods to accelerate well.
Car: 1988 Camaro Sport Coupe
Engine: 305 TBI
its ok dude, ur car is so much prettier than mine lol. he is my brother and we both own camaros how tight is that? the cooler thing is my dad has a 69 project in the driveway too so we're just a camaro family. ok question for everyone to add to his, is 3 inch exhaust too big? cuz my dad seems to think that since the 305 has a small cam and everything that ud lose too much back pressure and he thinks 2.5" would be much better, anyone w/ ideas id appreciate and i am planning on doin more mods i just bought the car this past week and the next mod ill save up for crush bent piping, however i did get my 3.5" chrome tips put on today and i must say they look beautiful!!! anywho ideas would be great for me and my brother as we are both new members.
i have 2.25 in exhaust and im putting over 450 at the crank. so id say do what ever you want. i have steps from headers so it helps the scavanging also i have deltass40 mufflers. so it all depends. ive seen 100hp cars with 5in exhaust and 500 hp cars with 3in exhaust its all up to you and their all better than stock. me on the other hand have stock exhaust on the l69
Car: 84 Z28
You are kidding right....
My car has 300 hp and is just fine, except for the fragged rear axle, but it has over 100k on it. subframes are not absolutely necessary thoguh they do certainly help. I'm talking street car here, not race car.
and yes, a 14 second camaro will do just fine with a stock chassis. 14s aren't that fast.
Car: 87 formie
Engine: none
Transmission: none
so an 82 camaros chassis with over 200,000 miles on it is as strong as a 2002 camaro chassis with 20,000 miles on it?
sorry, i find that hard to believe.
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
absolutley not. the chassis is basically the same as a 4th gen. the 4th gen come stock with 325 hp so there you go. A good driver is more important than an aftermarket aided chassis.
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
i totally agree with you shifty. anytime you startadding stuff the the 3rd gen cars you have o add suspension stuff your you will need new tires every 6 months!!
Car: 89 Camaro RS
Engine: 350 carbed now
Transmission: World Class T5
Axle/Gears: Peg Leg w/ 3.73's
UncleSam89 Where in houston are you guys I am just outside you guys in katy. If you want some helpful info on making your car a little faster go to the tbi boards there is alot of helpful info there. If I were you I would start out with headers, a high flow cat, and a 3inch cat back exhaust. That will make a pretty significant improvement. Also if you have like $20 to spare go up to autozone and get an open element filter that actually makes a noticable difference aswell, not huge but noticable. After that try and get some better gears, a good intake, and build your suspension a little and you will have a nice high 14 second car. Good Luck.
in the elco all i have is the cage thats my only mod to the frame. and air shocks. becareful when u get new gears to get new axles and while ur at it get a new posi unit
o yeah i have 430 at the crank not 450 sorry typo
Car: 84 Z28
Yes I've driven both LT1 and LS1 4th gens and gotten a good launch, however, what you consider good may be different than what I consider good. If you have a 14 second camaro, you aren't really concerned about cutting 2 tenths off your 60', right?
I'm not saying SFCs are unnecessary, just that you don't need them on a lightly modded TBI that goes 14s. If money is a concern, the car isn't going to explode if you don't have SFCs and new trailing arms.
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Engine: 305 TBI
another question, what is a good amount to advance your timing? im going to do mine w/ my dad this weekend and i was thinking advancing it 6 degrees, could i go more? will i see much more of a difference?
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Car: 84 Z28
True. I would rather just dump money on motor mods, I never make it to a dragstrip. Maybe spending money on suspension/chassis is a way of planning ahead. I dunno, I'd rather wait and do the mods after I have the power, it's more fun that way.
Car: 1989 Camaro RS
Engine: 305 TBI
Car: 89 Camaro RS
Oh thats cool, check out the south central region board. We are going to have a Texas meet sometime this summer. There was one in december that I missed, but I heard there was a good amount of cars there and everyone had a good time, so keep your eyes out on that board because I am sure they will start planning the meet soon.
Originally posted by ShiftyCapone
Well normally I would agree with you but recenty a guy added drag radials, and a slew of new suspension stuff and took his basically stock LO3 to a 14.7 ET. Without those mods he would have been mid 15. Sure his trap speed was slow but boy did he knock off some serious time with his ability to launch. Now add more power and you have a winning combo.
A guy at our track here did new LCA and sub frame connectors and kept his regular street radials. He can no longer run the 13.8s he used to run. He now runs mid 14s. His traction got worse. I'm not saying supsension ugrades are not a good thing, but for cars around 300 hp, a good set of tires makes all the difference in the world. I mean you shouldn't be getting wheel hop if your tires are sticky enough to hook up, and unless your lifting the front tire, you shouldn't be getting body twist very badly.
Re: sad realization...
The most important thing you can do, in my opinion, is don't be afraid of losing. There is always someone else faster than you out there, and you learn a lot whether you win or lose every time you run.
Here is ol' vwdave's suggestions. Difficulty is not a issue to these guys since their dad probably knows whats going on. Price is what I am going for here.
Bump timing to 6-8* (Free)
Open Element air cleaner
K&N filter ($40)
Headers (With removal of smog crap $100-$200, makes tons of difference)
V6 rearend. ($100 at most. 3.42 non-posi)
SLP Take out posi ($100 + Installation)
LT1 Cam ($20-$50 Get on ebay or a local f-body club)
95+ 4.3 S10 converter (got mine for $100)
Piece of steel thats 3/8" thick and box your LCA's (Price of steel and welder)
Spohn Relocation brackets ($80)
Torque arm bushing ($12 from summit and it helped)
Get a chip tuned for that car.
Have fun.
Just for the hell of it. I run the torque arm bushing, 3.42 posi, relocation brackets and 265/50/15 BFG Radial TA's and I will get out of the hole so hard I make girl's bras pop loose. Driver has alot to do with it. Oh yeah, launching at near idle and on a slightly modded L98.
K&N filter ($40)
Have fun.
Car: 1999 Chevy Cavalier
Engine: 2.2
Axle/Gears: it's part of the transmission
I added the Hotchkis rear end stabilizer kit and upgraded to 16x8" rims with Khumo Ecsta tires. I didn't have an extreemly powerful car, but I could not get my rear wheels to spin no matter what I did, hardly even a squeel....it just went, I also had KYB-GR-2 shocks in the rear.
Suspension is the best all around bang for your buck, if you do it right and use good parts, you experience everything better from the car.
Better take-off, braking, handling..overall stability...it makes the car alot more better to drive. You don't have to lower either, but that's pretty fun too! Those who say that stock suspensions are good, have never driven a car with aftermarket suspensions. SFCs will definitly help, even if you drive great, you can still launch better. Just talk to some of the guys in the suspension forums, most agree that SBCs were noticable just driving down the street.
Car: too many ...
If I still had a L03 motor, I wouldn't spend a dime on it performance wise. I did dump some cash into my 89 RS when it had a L03 and it was still veeery slow. Waste of money. If I still had that motor in my car and I wanted to make a big performance gain, I would seriously switch the heads (get away from the L03 heads) and change the intake to either TPI or Carb. You could go with a set of used OEM heads and the entire swap (inc intake) would probably cost less than $700 if you did the work yourself. Other than that, all the little TBI mods add up ($$) and the gains are minimal. If completely changing the L03 is not something you want to do right now, maybe look into some supporting mods (exhaust, gears, suspension, etc) that could be used with a different motor setup later on down the road. That will probably be the best bang for your buck in the longrun.
Car: 1987 Iroc Z28
Engine: The KING of the 3rd gen TPI's.
Transmission: Beefed up T5
Axle/Gears: Aussie 3.45's
Not to discourage, but I strongly agree with Crazy Hawaiian. There was a point where I dumped alot of money in my original LB9. Now that I think about it I could have better pissed away that cash on beer :lala:
Engine: 2.2
Suspension makes the whole car better, so it's never a waste of money...unless your car is a rust bucket.
I agree, save the money for beer...or a new motor!
Car: 1986 IROC-Z
Engine: 305 T.P.I.
at least it isn't a 1986 305 like mine
i say if you whant low 13's and under save money and get a 350.
Car: 1989 TTA
Engine: LC2
Transmission: Worn-out 200R4
Axle/Gears: BW 9-bolt, 3.27's
Check out www.goingfaster.com it has a LOT of stuff for LO3 build-ups, even though his current toy is an L98 Formula now - he's had a lot of experience with TBI and modding them out. Compared to a carb, TBI is like, super-intelligent, using a chip to control fuel delivery, rahter than engine vacuum. However, I'm not about to start a fuel delivery argument, but you can stick with what you have and make some decent power.
86CamaroDan
09-29-2015 10:08 PM
