How much is stock intake holding me back?
Car: 92 Camaro RS
Engine: ZZ4 350 TBI
Transmission: 700-R4
I have a zz4 engine but it still has the stock tbi intake manifold and tbi. How much do you think this is holding me back from the engines potential, and how much would i gain from going to say a holley tbi intake and 670 tbi?
Car: 92 Camaro RS
Engine: ZZ4 350 TBI
Also another question. Do you think i would gain more from changing the intake or doing a full exhaust change? I still have complete stock exhaust on the car.
Car: '87 Formula
It's probably holding it back a lot, first question. I'd say you'd gain a lot by going with a bigger TBI unit and better intake. And for the last question, definitely go with the exhaust, with headers.
1 Post
Car: 92RS
Engine: 357
Opening up the intake restriction won't do much good till you open up the exhaust with headers and 3" cat back exhaust. Do both or its never going to breath right. I'll bet good running LO3s are spanking you right now.
Car: 92 Camaro RS
Engine: ZZ4 350 TBI
Well the car now can keep up with or beat my neighbors 86 z28 with a gm 350 HO crate engine. I was thinking before of switching to carb, because it might be more cost effective, but now im leaning more towards sticking with tbi.
Car: 89 Camaro RS
Engine: 350 carbed now
Transmission: World Class T5
Axle/Gears: Peg Leg w/ 3.73's
The stock tbi intake and exhaust on that zz4 is probably robbing you of a good 40 hp easily. If I were you I would invest in some headers, a high flow cat, and a 3 inch cat back exhuast. Youll see a huge difference with that. After that go with a good intake like the performer if you need to keep the egr or performer RPM if you dont need it(stay away from that holley tbi manifold ive heard its crap).You can use any carb manifold as long as you buy the tbi adapter that turbo city makes. Then top it off with the holley 670 tbi and you will knock a good amount of time off of your ets. Good Luck.
Car: 1992 Camaro RS
Engine: 305 TBI
Transmission: 700R-4
yeah, i cant imagine how much more power you will gain with both proper air/fuel flow and exhaust flow. most guys after doing heads, cam swap have to install a bigger fuel system, so you are even ahead of them. i would probably agree with the atleast 40 HP and that's at the wheels would be my guess, your choking the day lights out of that 350, it's hard on a 305 much less the 350. you should get it dyno'd now and then dyno it again after you do intake and exhaust and see how much more power you gain, you will surely feel a SOTP difference and the gain on paper should be a big number too!
Car: 92 Camaro RS
Engine: ZZ4 350 TBI
I figured it was robbing me alot. So the exhaust should be the first priority then, and after that worry about intake?
Car: 89 Camaro RS
Yeah the exhaust is definetly going to be your first priority, if you do the intake first your engine is going to be able to take in more air but it wont be able to push it out through the stock exhaust. So if you do the exhaust first you will see bigger gains when you do the intake.
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Do you have a high flow fuel pump? I would get that right away before you make the motor breath anymore. You better also get into chip tuning really quick or the car will never run right when you get it opened up. With the stock tune, TBI, intake and exhuast I bet that motor is only making 200hp. I put your power loss way higher than the 40hp most people are saying. This is the order of stuf I would do to prevent damage to your motor and to get the most out of it.
Fuel pump
Chip burning
Full Exhuast and more chip burning
intake manfold with larger TBI unit and inectors
As you soon as you open that motor up you are going to expose every weak link found on these cars all at once. You are better off buying all of the stuff and doing it at once.
Fuel pump
Chip burning
Car: 92 Camaro RS
Engine: ZZ4 350 TBI
So if I were to change the exhaust to headers and 3 inch the rest of the way, it would run the same or worse before i did any chip burning?
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Car: 1992 Camaro RS
Engine: 305 TBI
http://www.jegs.com/cgi-bin/ncommerc...69&prmenbr=361 i believe this is it, not 100% sure but i think this would work.
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Originally posted by 1fast91rs
does anyone have the link to where i can buy a tbi adapter plate so i can use a carb intake?
Car: '92 droptop bird
Engine: 5.7L,mild cam etc.
Transmission: modded 700r4 w/2600
considering the factory TBI intake does not flow past 4200 rpm i would say that is the biggest restriction.
gees that reminds me i need to change my intake, all those mods and ill never feel them i cant figure out why the Edelbrock TBI intake is so much more then a standard carbed intake.
Car: '87 Formula
Probably because they are more specific as to what bolts on to them. As in, the TBI unit as opposed to carbs being pretty much standardized on how they mount.
Fast355
12-02-2016 06:33 PM
