Noisy injectors?
Car: 1992 Camaro RS 25th Aniversarry Edition
Transmission: TH-700-R4
Axle/Gears: 10 bolt with 3.23's and SLP Posi.
Noisy injectors?
how noisy should my injectors be? they are quite loud at idle and can be heard eaisly without opening the hood. i do have a Open element withe a K&N filter. is it normal to hear them "hiss" our should i not be able to hear them at idle? runs fine just dont know if thats normal.
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Noisy injectors?
1 Post
Car: 1991 Chevy Camaro
Engine: 305 TBI
That's what that noise is! I installed an open element and since then I started hearing that noise but I didn't think about it. I kinda didn't like it at first but now I think its pretty cool.
Re: Re: Noisy injectors?
Originally posted by ShiftyCapone
It is normal. The tock air cleaner assemply does a good job of dampening out any sounds from the incomming air and injectors tick/hiss. I think it sounds really cool and is a sound you don't hear on your regular every day small block.
after a little playing around with it i noticed that it is REALLY loud when its cold but when it warms up it goes to the sound i like. the sound you are describing
Some of the hiss you are hearing is probably the idle air control valve (IAC). As the engine warms up the valve closes a lot but not completely. The injectors make more of a ticking sound, I've never herd mine hiss before.
Steve
Steve
dimented24x7
09-06-2015 03:51 PM
