ZZ4 Camshaft
Car: 1992 camaro RS
Engine: 305 TBI
Transmission: T700-R4
ZZ4 Camshaft
for a 305, is this a good choice for a street car? i can get a ZZ4 cam for cheaper than i can get a LS1 cam where i live. all i want to know is the ZZ4 a decent cam compaired to the LS1 cam.
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
ls1 cam won't work.
zz4 is not bad, it is a little large on the exuast side IMHO, but should be descent. it will of course require a quite a bit of tuning.
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Originally posted by Dewey316
ls1 cam won't work.
ls1 cam won't work.
LS1 is a completely different animal. Its like trying to fit LT5 heads on a LT1....wont work. Now a ZZ4 cam, with SDPC vortech heads is a very nice set up. But it will require a great deal of tuning, but its doable.
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
I think a guy on here "JokerRS" IIRC is running a ZZ4 cam in his 305, search for him maybe and check out his profile if he has anything there.
Car: 96 SS, 88 IROC
Engine: Lt1, TPI
Transmission: m6,a4
Axle/Gears: 3.90. 3.73
My lt4hot cam deal feel threw and I will be running a COMPLETE ZZ4 top end on my 305 from cam to heads... Along with victor jr intake... Im starting the swap in 2weeks... HEHEHE ill be in for quite a bit of tuning. but in the end I just want my start and go thing i do now. only reason im not going to carb is cuz i dont like to let it warm up. also ill be running 1.6rr with the zz4 cam thats .544 max lift heads have new springs to handle it woooooo
Car: 96 SS, 88 IROC
Engine: Lt1, TPI
Transmission: m6,a4
Originally posted by aklaim
You should be in good shape with the proper tune!
Yea I guess i should look into tuning my own chips, but i dont wanna, lmao... Ill drive the 200-300 miles to have someone do it for me... Im doing all the really hard stuff myself.
Car: 1992 camaro RS
Engine: 305 TBI
Ok thats what i liek to hear.
My plan befor i thought of getting the ZZ4 cam was:
Vortec heads, LS1 cam, Performer intake (vortec version).
now it looks like the ZZ4 cam would be a good choice.
As far as tuning goes, i know im definetly going to need it.
but i dont know where to start or what id be doing to make it better for that setup.
so i might get it cutom tuned i dunno, i would need someone who in the future could help me out?
thanks
thanks
1 Post
Car: 92RS
Engine: 357
I like the ZZ4 cam myself. It acts like a bigger cam then it looks like on paper. Any 350 cam acts bigger in a 305. Definantly needs tuning to be drivable at all. I wouldnt try driving 200-300 miles with a stock chip to get it tuned. It will run extremely rich at idle and cruise till its tuned. It allso needs alot of timing added through out the spark chart but once its tuned its very drivable. I think it took us about 28 chips to get there. That was VE, spark, and PE tuning with half of them being PE tuning with a G-tec.
I am getting ready to slap all my goodies on a 350 short block this spring so I'll have to start tunning all over again.
PS does any body have a pair of 85# injectors for sale?
Car: 1992 camaro RS
Engine: 305 TBI
So in other words, this cam would be very hard for a first timer to tune?
Also, would you consider this to be a mild cam? or whatever
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Car: 1992 camaro RS
Engine: 305 TBI
ok. well im gonna learn how to tune eventualy so its gonna happen with this ZZ4, even if its hard. i have you people to help me right
Car: 1992 camaro RS
Engine: 305 TBI
Oh and when its in it will be companyied by new heads and intake mani, with a bigger fuel pump as well. so all that would have to eb factored into the tuen as well. i was going for vortec heads with one of thoes edelbrock performer[whatever] intakes.
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Engine: 305 TBI
I would jump right into prom tuning right now on your stock engine and learn it quite well before you dive into that big of a project. If you don't learn chip tuning now and get it down fairly well before this head, cam, intake swap I see a carb in your future (or a very poorly running TBI engine).
Car: 1992 camaro RS
Engine: 305 TBI
Well it sounds like you are on the right track. I would make sure you do plenty of reasearch first before you start to buy stuff
If anyone knows could sombody tell me if the ZZ4 cam, 1.5 rockers(or whatever rocker at all), and teh vortec head would work ok? because if that combination works out then thats what its gonna be.
Thanks everyone :hail:
Car: 1990 Camaro RS
208/221
.474"/.510"
112
are the specs listed for that cam, i don't know if those are 1.5 or 1.6 lift numbers, if they are 1.5, they will not work on a stock head. if they are 1.6 numbers, with 1.5 they would be.
.444 .478
that .477 exaust would worry me on any unmodified stock head. alot of people say they will 'take .480' and they might, but i would leave a larger saftey margin. you really need to check the point at which things hit, and check your clearnaces, they DO VARY from head to head, quality control is just not that great
.474"/.510"
112
.444 .478
Car: 91 RS
The Vortec's that I have had a retainer to seal clearance of .465"
The ZZ4 cam spec's are stated at 1.5. I'm going to use this cam with 1.6 rockers for a final lifts of .506/544". The stock Vortecs will not work either way.
The guides will need to be cut down to give lift plus .060" clearance. Larger springs will also need to be machined for and installed.
1 Post
Car: 92RS
Engine: 357
Definantly not a mild cam in a 305. Has a noticeable powerband of about 2500 to arround 6000 in my setup. It doesn't really bog but a 2500 stall converter would be nice.
Car: 1992 camaro RS
Engine: 305 TBI
hmm, so if i used vortec heads with a ZZ4 cam what would i have to do to make it fit? more detail plz.
Car: 91 RS
The second issue is you are going to need larger springs. Some people swear that you can use some that are "rated" for .500 plus lift that fit the standard 1.25" spring pocket and say that they are working fine. More power to them. I'm going for a more bullet proof setup for "endurance running" on a road circuit hopefully. I do not have a problem with spending more or doing more work to get there. If you want less work to the heads use a cam with less lift. There are several good ones. The ZZ4 was only $95 new is one reason that I'm using it. Either way I would not run the stock Vortec springs. You can run up to .480 lift with only shimming the springs up .060" and using offset locks as I did for the LT4 stock cam with 1.6 rockers giving a final lift of .480. It still did not get the desired .060 clearance but its working with about .035" which is "pushing it".
Do you have any other cam choices?
DM
88SS6SPEED
11-11-2015 07:05 AM
GTAman
09-26-2015 02:01 PM
