TBI guru's: My TBI motor died while I was driving and won't restart!
1 Post
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
I was coming home from work yesterday and I was doing like 45 when the tach dropped to 0. My motor had died so I put it in neutral and pushed the clutch in and tried to restart it and nothing. I finally had to coast off to the side of the road and have my dad pull me home. It cranks fine (new igniton switch) and there is no vats problems, I saw fuel coming out of my injectors but the thing just won't kick over, it just cranks. I haven't had a chance to check the ignition system but I just did a tune up this weekend(plugs ,wires, old accel coil,cap,rotor).I figured that there is either no spark, or no fuel, cause the motor is in great shape otherwise. I also thought that it could be my fuel pump and that the fuel coming out of the injectors was just left over pressure.
Need help.
Need help.
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Sounds like the same thing happend to me. Driving and then just stopped and could not stay running. That is a fuel pump if I had to geuss. I could still see fuel coming out of my injectors so I thougth other wise, plus my pump still made noise. So I tried a trillion other things and was forced to take it to someone. It was a fuel pump and it didn't entirely die but only could supply like 5psi at wot. That is not even enough to get your car to idle.
Car: '92 droptop bird
Engine: 5.7L,mild cam etc.
Transmission: modded 700r4 w/2600
pull your dist. cap off to see if rotor is spinning while you crank it...could be a fauly fuel pump though....
Car: 1991 Camaro RS
Engine: Briggs & Straton
Transmission: Centrifical Clutch
I'm with gen3z, pull the cap and see if the rotor spins when you crank it. I had the exact same thing happen to my 85 SC (LG4). Went to make a left turn and it just died and never started again...ended up being a broken timing chain.
1 Post
NOT ANOTHER REPAIR!!
Oh well, I'd rather it be the timing chain than the fuel pump, I can at least fix that.
Originally posted by steve8586iroc
I would also check the ign module. Same thing happened to my truck and thats what it turned out to be. Or it could be a fuel pump.
Steve
Steve
1 Post
Ignition Module
It was the ignition module! I trouble shooted all the things you guys told me and since I had extra modules and coil's I kept changing them until it started. Thanks guys! TBI remains invincibly reliable.
