cheap good cam for a 1989 305 TBI
Josh Try here for takeoff cam www.goautocenter.com
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
The vortech cam is a bit smaller than the LT1 but will still work fine. You can re-use your rockers, pushrods, and lifters with either of those cams. You will want to change out the valve springs but that is no big deal. You will want to look into a custom tune to maximise both of those cams potential. You will be happy with either of those but I would go with the LT1. It is a bit bigger, and can be had for the same price.
Josh the cams at the go auto center have virtually zero miles on them what they came out of I dont know these are chevy stock rollers and a few zz4 take offs. people buy engines from this place and swap the cams in them for something else before the engine is installed. figure out what you want for cam specs and go for it. these cams are cheap....they go for almost 3times what these are new. Oh and these guys are good to work with i have bought stuff from them before
for what its worth I like the specs on the first cam for a 305 the lift wont be a problem with stock springs and the 109 lobe seperation will offer a nice smooth idle
If you order the cam from Go auto buy the bronze gear from them too.....its cheaper than any other place that sells them. Do not use the old cast iron gear with these cams.
Car: 1991 Camaro RS
Engine: Briggs & Straton
Transmission: Centrifical Clutch
Porting the stock TBI heads is the equivilent of pissing in the wind. The best thing you could do to those heads is a 3-angle valve job.
BTW, the LT1 cam I have came out of a 94 T/A with 60k miles on it and the only reason is was removed is cuz the guy went with the LT4 hot cam kit.
If you're intrested in buying the cam hit me up on AIM at: BadBlue91RS
Car: 1991 Camaro RS
The 3-angle valve job is a angle cut they put on the heads (not too sure about the job myself) and would cost you roughly $100 to get done. You can most definently port the heads, but it will yeild minimal results due to the MAJOR casting imperfections on the TBI heads.
I'm not gonna be useing the LT1 cam like I planned cuz I came accross a 400 sbc for $200 and i'm gonna build that up with my huge incometax check.
You could get yourself some fairly cheap shorty heads and a cat-back system. That would REALLY give you some results on the butt-dyno.
Go to the machine shop that will do the valve job and ask them if they have a set of 416 or 081 heads for you to buy....Since you are on a budget you should get these for cheap Take them home and port and polish and have 1.94 valves installed on the intake side. I promise with the cam we discussed from go auto you will see a modest improvemnt. atleast I did with my 305 the bottleneck in these engines is the exhaust system...it is way to small for these engines. that should be your next upgrade after getting some decent heads..I doubt a 3 angle valve job will yeild you any gains with your current heads....if you have a boat they make great anchors.
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Originally posted by joshwilson3
What do I need to know when this gets installed? I think for simplicity I'll stick with the LT1 cam. I will get this done labor free at a local tech school.
I see you have to grind something. What is it and how much you grind it? Does anything else need to be modified? Can I use my stock lifters, rods, and rockers? Do I have to use a special timing set or anything? What's a good timing set for this LT1 cam in a 305 block?
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
I will probably get the competition products VSA 3 spring kit for $50. cloyes double roller for $50 or so. Felpro valve seals. And still looking at the gasket kit I would need. I though that I would need a roller timing chain for my roller cam? I was gonna go GM single row roller chain, but people said to go with Cloyes. So I'll probably get a Cloyes true double roller timing set.
What are some better heads that I could get? I figure I might could find some used heads. Are 350 heads better than 305 heads? and will they work? Would LT1 heads work? Or the L98, or ZZ4? Tell me what will work, and I'll start searching the classifieds.
I could probably find something in the junk yard. Tell me what heads to look for that will fit on the 305 and work well.
Now as for gasket set there isn't a whole set. You need to get a timing cover gasket set (comes with timing cover gaskets and water pump gasket)
Intake manifold gaskets (comes with distribuotr gaskets and water neck/thermostat)
It may also be a good time to chang eout your TBI gasket as well. You will have it of so might as well replace it. This is just to get you started and a search on the matter will have you reading for days.
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
How does this timing chain look?
Part #12371043
www.sdpc2000.com/cart.asp?action=prod_detail&catid=887&pid=1858
Would that be a good single roller timing chain? It is a GM performance parts item?
thanks
Part #12371043
thanks
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
i have a true roller, its summit brand, cost $42.
after comparing it side by side with a compcams chain, it is the same thing. casting markes, numbering, ect is all the same.
http://store.summitracing.com/partde...rt=SUM%2DG6601
Car: 1990 Camaro RS
it is a double roller.
it is exactly the same as this compcams part.
http://store.summitracing.com/partde...art=CCA%2D2136
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Car: 1990 Camaro RS
the price was right on it that is really the only reason i went with such a stout chain. come on shifty, i like overkill, i had to talk myself out of the jessel belt drive.
as for fitting, it should, but i won't know until i get everything installed.
**note** if i get donations for the 'Help John Go Fast' fund, it will get installed sooner
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Car: 1990 Camaro RS
yes, it would be serious overkill on a bone stocker. it is going on when i finaly get around to the head/cam/intake swap. i am so close, but still need some misc. stuff (gasket set, pushrods, ect) to do it. everyone cross your fingers that when i do taxes this week, it is good news, if i have to pay out on them, the project is on hold for even longer
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Car: 1990 Camaro RS
yes, i have 416, they are ported, i have the studs/guideplates, valves, ect for them, i just need to get them to the machine shop so they can take care of the stud bosses as valveguides for me, since i will have about .525 lift. i have the full roller rockers, cam (sort of, that is a long story, btw, anyone want to buy a UltraDyne racing cam ), intake, and timing chain. i still need, the pushrods, gaskets, fluids, and holley TB. then i am golden. the project got set back, i bought another car, so that i dont' have to drive the camaro to work, it is a garage queen now, i also moved in mid dec. so the moving costs, ect and the new car, put a halt on play money for me.
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Car: 1990 Camaro RS
no i haven't, i need to do some math i will likely go with the big boys (85pph ?? ) i THINK this combo can go 300hp at the crank, in which case i would need the big bad injectors.
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Car: 1990 Camaro RS
that is what i figured, i would rather have to tune them down, as opposed to trying to crank up the pressure, and find out they go static at like 4k
