Looking for this air cleaner assembly
Car: Red 91 RS Camaro
Engine: LO3 with Comp Cam
Axle/Gears: 4th gen rear
I'm looking for a part that looks like the attached picture so I can do my own air cleaner/cold air assembly. Any leads would be awesome cause this K&N model is WAY too expensive.
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
I think you can go through some junkyards and try to find a Cadillac TBI aircleaner. I'm pretty sure some guys on here have done that and its a similar enclosed design like that.
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
Like Bron said, the caddy cleaner can be had for $10 from a junkyard. You'll need to cut the bottom down a little, as it sits a little high and at a slight angle.
It is what I use with my ram air mod
Car: 1988 Pontiac Firebird
Engine: 305 TBI
Transmission: 700 R4
http://knfilters.com/Racing/plenum.htm
Says it "works best" on 200 c.i.d. engines or less...so it might hurt more than help...
Oh and it costs $166 from Summit... http://store.summitracing.com/produc...earchType=ECat
Hmm, Summit said nothing about that.
What does the Caddy cleaner look like and what year span or model did it come on cause I'm no Caddy expert.
Car: 91RS
Engine: 305tbi
If you look at the details you can find the 200ci thing. Thanks for the link, ill look for the caddy one though.
Any idea what years/models they came on, there arn't any pick a parts around here, you have to know exactly what you want.
Car: 93 GM300 platforms
Engine: LO3, LO5
Transmission: MD8 x2
https://www.thirdgen.org/techbb2/sho...&highlight=pvc
Here's one example, as used on a 93 Caprice with the TBI 350. Note that it's an elbow not really an air cleaner. They were used on late 80s / early 90s fwd v8 Cadillacs.
Hotrodboba400
12-10-2019 07:07 PM
Night rider327
09-02-2015 04:17 AM
