speedo gears question
First off, what drive/driven combo did gm put in the 2.73 equipped auto L03's in 92? Second, those of you who swapped to 3.42's, what speedo gears did you go with?
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
All of the T5 cars got the 3.08 peg leg base. That is for the RS models. The Z's could get the 3.42's with posi with the T5. The RS auto cars got the 2.73 peg leg and the auto Z's got the 3.23 with posi. These options prety much stayed consistant all the way up to the f-bodies last production days in 2002. As for speedo gear I only know about the T5 ones. I assume you have an auto?
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
shifty, what T5 gears do you need for 3.42's
one of these days i probably shoudl do my speedo gears when i actualy changed gears i called a couple of dealers and never got anywhere
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Car: 2002 Z28
i only paid about $10 for my gears. There is an old post on the boards that lists every speedo gear and its part number for the cable and electronic driven th700r4 and for the T5. I would do a search if i were you.
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Car: 2002 Z28
under transmission to the left of his profile it says: 4L60 so i was just assuming he was talking about a th700r4. Changing the gears on the auto are a bitch also, you have to remove the torque arm in order to get the tailshaft housing off but only if he has to change the drive gear. He might we able to get away with just using a 45 driven gear and keeping the 17 drive gear depending on his tire size.
Car: 1990 Camaro RS
thanks shifty, i just couldn't get a clear answer from the dealers that i went to. they kept trying to calcute what i woudl need base on the car i had, too bad i drove the RS there, becuase they saw the RS badges, and tried to tell me i didnt' have a 3.42 rear or TPI.
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Anyways,
I cannot find the pic on my computer but here is a thread that i responded to that has the pic I wanted to show. I can get you some more later to show you the gears up close.
https://www.thirdgen.org/techbb2/sho...t=Speedo+Gears
They are both AC Delco parts and here are their AC and GM part numbers. They share the same part numbers.
For the round purple one
ACD# 14071731
GM# 14071731
and for the shaft mounted one
ACD# 14090592
GM# 14090592
Car: 1990 Camaro RS
thanks shifty!
BTW, can't tell in the picture, but is it the purple/white gear combo, that is what i cam up with on my own, and the GM guys tried to tell me otherwise, and confused me
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
thanks shifty!
thanks shifty!
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Ok here is a pic. It is still not the best but i don't really want to take it out of the plastic yet. I had to order them separately because they only had one in stock. It looks like the purple one cost me about $6. I think the white on with the shaft cost $20.
ambainb
04-25-2016 09:21 PM
beachrodder
08-07-2015 04:27 PM
