stock Lo3s w/T-5 tranny
Car: 91 RS
Engine: LO3
im begining to think my tach is fubar. with 308 gears, and under WOT, what mph are you guys shifting from 4th to 5th? i shift around 90-100 mph. something tells me this just isnt right, but the car seems to run faster that way. to sum it up, should i be running 4th gear to 100mph? the tach is reading like 6000 plus. i know, im the king of over reving.
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
It has been awhile since I drove mine but mathmatically you should be at 109mph at the top of fourth at 5000rpm. Now this is with a 245/50/16 tire. I do ermeber not quite being able to hit the limiter at the top of fourth.
1 Post
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
Nick,
Factory tachs just plain suck. I am on my third cluster. 1st had a bad tach. Replaced it and watched the speedo die a year later. So I went with a 145 mph cluster to find out that tach was bad!
Anyways, there are two easy ways of checking for accuracy.
1) The equations on this page https://www.thirdgen.org/newdesign/t...ulations.shtml . You know that fourth gear is a 1:1 ratio, and you are running 3.08 gear, at say 5,000rpm. The only thing in question is your tire radius. Just assuming 12", it comes out to be 115.9mph at 5,000 rpm.
2) Winaldl. It displays the rpms you are actually running at what speed, given that your computer is reading the correct rpms. From my experiance, a bad tach (i.e. on that reads more than actual) does not effect the signal going to the computer. Though I guess it is possible for the dissy signal to be messed up, but I don't think that is a common problem
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
i've never seen a dizzy sending problem, that would cause a host of other issues.
like other said, chances are your tach is wacked, i have a picture of my car on the dyno, the pickup on the #1 plug for the dyno was reading 4800rpm, my tach is burried in the dash . and if it helps, with 3.08's T5, 235/60/15's on my car, when i ran my car up close to 5k, i was doing about 120mph according the dyno. i can try to copy/paste the dyno print out of showing MPH/RPM from the run, when i get home from work, i will try to get it and post.
Car: 91 RS
I'm with Dewey.......no dyno but it's closer to 130 when mine needs shifting at over 5k. Too busy watching the road to get exact readings. This is with 255 50 16's and Autometer tach.
Engine: slowtacular L03 305
Transmission: slushem 700r4
Just to chime in, while i do have an auto, my tach will bury itself past 7k on a a WOT romp from a stop through first into second. That is with the tranny doing the shifting. I don't think i have seen or know of anyone with a 305 that can rev like that. (could be wrong, there are some wicked combos lurking on this board) Gm put some crap tachs into these cars. If your speedo is accurate just go by that untill you find a nice aftermarket.
Car: 91 RS
Engine: LO3
thanx on the info guys. i took her out on the highway last nite and woo hoo! 4th gear up to 110. i was very impressed. i was shifting around 90-100, totaly shorting myself. that felt incredible, felt as though i had made some serious mod. and all it took was to run the damn engine to its actuall shift point. destroyed an SHO last nite, though i coulda really embarresed his *** if i had no speed limiter. i think mine was just a touch before his which means that had we continued, i wouda been way farther up front. thanx so much for your replies guys. while i used to think my whip was patheticly slow, i now have rejuvinated hope...shhh...i know, its still slow. but it burns the ricers stop lite to stop lite
Car: 1990 Camaro RS
at the stip i let the tach hit the dash, then count to 2 mississippi
Genopsyde
10-07-2015 08:35 PM
Zachattack0925
08-12-2015 09:54 PM
Zachattack0925
08-12-2015 09:52 PM
