Lost my keys....what are my options?
Car: '91 Firebird
Engine: 305 TBI
I lost my keys at work on a 275 acre ranch. What is my best option for dealing with that situation? I was thinking buying a chip with vats deleted and getting new ignition cylinder and a new set of keys. Thanks for any help.
Car: 91RS
Engine: 305tbi
Why do you only have 1 set of keys?
Maybie a dealer could get you a new set, maybie you can get lucky and find a spare key under the carpeting as a couple people have
You don't have the knockouts from the original keys with the keycodes on them do you, a locksmith may be able to use those to make you a new key.
Well first you should have more than one set of keys.
A dealer might be able to get you a new key using the VIN number, doubtfull though. Maybie you can find a spare key under the carpet like a couple people on here have.
I would think thats pretty much your only option, getting a new cylender and disabling the vats unless someone else has an idea.
Maybie you could install a pushbutton start that doesn't use a key, because that wouldn't make it easy to steal
Car: 86 IROC
Transmission: WC T5
I think after 1988 you can go to most locksmiths and give them the vin and they can get the cut codes. If you still have the knock outs from your keys with the 4 letter/digit code, Use that.
Car: '92 droptop bird
Engine: 5.7L,mild cam etc.
Transmission: modded 700r4 w/2600
call a mobile locksmith,he will cut you a key on the spot,as for the door locks,pull the hatch compartment lock and have him re-key it,getting into the car is easy use the factory anttena.
Car: 91RS
Engine: 305tbi
Really? The locksmith around here told me that he couldn't make a new key for the ignition or the doors in my 91 without the codes or an original key.
It took something like 7 keys before the locksmith got the right key for her car. The turn was no problem and the cut was no problem... it was the code that was the problem. Be sure you know your code number too. If you do, you're fine. If not, it is hit and miss with the locksmith.
Car: 88 TBI Formula, 98 LS1 TA, 77 400 T
Go to the dealer. Give him your VIN. GM will fax him the key codes and vats codes for your car. You will need to give him proof that the car is yours (registration, title, etc.) because if he cut a key for every person with a vin number, he would get sued by the people getting their car stolen. Dealer can cut a key in 5 min. I know I have had it done for my 88 Formula.
If the ignition lock and door locks are factory...no problem. If they have been changed some time in the cars past.....only choice is to replace locks with new ones off the shelf.
Car: 91RS
Engine: 305tbi
Stupid lieing locksmith, everyone around here is out to try and rip you off
I know its everywhere but we just have an overabundance of people who try and rip you off here.
My father paid $2500 to put a tranny in his minivan, I think that was rediculous.
Car: 86 IROC
Transmission: WC T5
At the lock shop I worked at, We had a 800 number to call with the vin. They then gave us the codes for the keys. We then looked up the codes in our book for the cut depths. The only thing I can't remember is if they gave us the vats #.
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
i went to the GM dealer and got a key for $25 one day when I broke my key. I didn't have my old key or anything, I just wrote down my VIN and brought it to them...
also a great idea to steal someone's car *whistles*
Car: 88 formula WS6
Engine: 305 Lo3
Transmission: 700-R4
My sugestion to you is either get rid of the woman that is distracting you or,m marry her, that way you won't loose your keys!
gixxer92
05-18-2017 11:20 AM
3.8TransAM
09-27-2015 08:37 PM
