I need a recomendation for a cam kit
Car: 89 camaro w/t-tops
Engine: lo3
89 rs lo3
Im changing my timing chain and decided to do the cam too.I'd like to do the LT1 swap.My roller lifters are pretty wore too so I need to replace them.Any ideas for a LT1 cam/roller lifter kit from Comp,Edlebrock,etc?A Summit part number would be helpful since thats where I'll be getting it.If you cant think of a kit, could someone recommend a lt1 style cam to me?Buying the cam and rollers seperately cost big $$$!!!Im hoping to find a kit thats cheaper than buying seperately.Thanks.
Car: 2002 Z28
just look for a stock LT1 cam, you can find them on www.camaroz28.com or ebay for pretty cheap. Also, how do you know your lifters are worn, roller lifters last for a long time, dont get them confused with regular flat tappet lifters.
Engine: lo3
The engine has 193000 miles on it.The roller portion had grooves in it and looked pretty fugly.I havnt pulled the pulled the peanut cam yet but I figure it to be wore too.
Im a little leary of a junkyard LT1.If I get one I'd want the rollers off the same engine that way they've wore together.Am I making sense?Im afraid the current rollers grooves and the lt1 grooves wont synch and mess something up.Maybe Im reading too far into things..... Wow...now I confused myself!!!
Car: 2002 Z28
you should be cool with some new lifters and a 50K mile or less LT1 cam, go to www.sdpc2000.com ,you can get Federal Mogul roller lifters for about 128 a set.
Mickeyruder
09-02-2015 02:45 PM
gixxer92
09-01-2015 04:32 PM
1988iroc350tpi
08-14-2015 07:52 PM
