ping??? never herd it
can someone enlighten me on the subject of ping??? i have never heard it i dont think??/ is it that rod knocking noise, is it a miss noise?,what is it??? ive been working on cars for a long time now and i can honestly say i have never heard the noise a car makes when its pinging. can someone help me figure this out??
1 Post
Car: 1992 Camaro RS
Engine: 355
Axle/Gears: 3.73:1
Grab a tin can, put some rocks in it, shake
That's about as close as I can think of.
It's not a tick, it's not a knock, it just sounds like a bunch of "ping"'s and usually occurs under heavy load (3/4 throttle or more). (FYI, PING = Pre-Ignition)
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
ping sounds just like the name implies. Light ping will literally sound like a metallic 'ping' thats actally a shock wave traveling tyhrough the engine from colliding flame fronts. If you listen closely, sometimes on a hot day in traffic with regular in the tank, you might be able to hear an occasional ping when you go to accelerate.
Originally posted by 88TRANS
What causes it... how do you avoid it, or get rid of it?
Colin 86&87 IROC-Z
10-10-2000 05:12 AM
