Valvesprings for L05 w/ LT1 cam
Car: 93 Caprice 9C1
Engine: L05
Transmission: 4L60
I have a 96 Z28 cam waiting to go into my L05 (hopefully within a month or two) and I was wondering what valve springs would be good to run with this cam. I would be looking for something around what a Z28 would have had stock, except that fit my L05 heads. I don't want to over-spring the valves (HP loss) but my 167k L05 springs probably won't do the job past 5000rpm.
Any ideas?
Any ideas?
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
Well...don't count on making any decent power past 5000 rpm with those heads. I've been there...
Check out the link...
http://www.competitionproducts.com/page32.html
I'm using the VSA 1 kit for with my Ram Jet cam. $30 for new GM springs/retainers/keepers...not too bad. You might want to go one step up if you plan on revving higher. I don't plan on going past 4800 rpm.
Car: 93 Caprice 9C1
Engine: L05
Transmission: 4L60
Thanks for the link. I think I'd want to go with the VSA 3s. Do you know what the seat diameter is for my VIN 7 L05? Is it 1.25"?
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
Car: Bee-Bowdy
Axle/Gears: fo-tins
Originally posted by brodyscamaro
I believe it is 1.250"
I have the printed version of the Competition Products catalog. The VSA 3 kit contains spring of the following specs:
#98214
Single spring w/damper
1.250" diameter
Seat pressure: 115# @1.700"
Open pressure: 300# @1.250"
Coil bind @ 1.160"
